Old 12-08-2018, 07:09 AM   #1
aliahmed13
Drives: Toyota Yaris
Water leak in driver footwell
Afternoon folks
Whenever it rains heavily, I notice water in the driver's footwell of my 53 plate Yaris. The photos are taken after there was rain overnight and as you can see, there is a fair bit of water. I am struggling to get my head around where it's coming from. Any help/solutions would be greatly appreciated!
https://ibb.co/tDkVYTk
https://ibb.co/sjhp65F
aliahmed13 is offline   Reply With Quote
Old 12-08-2018, 08:39 AM   #2
Did you drive it in the rain or it sat overnight under the rain?
Sent from my CLT-L04 using Tapatalk
Old 12-08-2018, 08:44 AM   #3
Wow! That's a crazy amount of water. Good luck figuring that one out.
Sent from my EML-L09 using Tapatalk
Old 12-08-2018, 08:57 AM   #4
ex-x-fire
Looks like the cowl drains get plugged up.
https://www.youtube.com/watch?v=Yk-SwvWxj6g
Old 12-08-2018, 09:58 AM   #5
aliahmed13
@IllusionX
It was parked up overnight and was like that in the morning
@ex-x-fire
Cheers, i'll have a look!
Old 12-08-2018, 03:47 PM   #6
Originally Posted by aliahmed13 View Post
@IllusionX
@ex-x-fire
Perhaps some seal are not tight, like door seals or windshield is leaking.
I can't see how a missing drain plug would flood your cabin overnight.
Old 12-08-2018, 05:27 PM   #7
dogsridewith
Drives: 2007 2-door hatchback
Yaris cabin floor water leak
OP: Which side is driver's side? Do HVAC box drain tube plug-ups always cause overflow onto right front side of the cabin floor? (Is anything up front different between left and right-hand drive Yarii except the steering wheel, glove boxes and passenger airbag location?)
2008 toyota yaris 2 door hatchback water leak knobby bobby DIY / Maintenance / Service 8 07-03-2024 06:42 AM
Water leak to passenger side AND driver side TMR3 DIY / Maintenance / Service 7 05-21-2017 07:19 AM
Water leak problem Yaris874 General Yaris / Vitz Discussion 5 04-10-2017 12:03 PM
water collecting in driver side rear footwell AmberNShakey DIY / Maintenance / Service 1 01-20-2014 03:48 PM
Water Leak! Failed Relays cfeng DIY / Maintenance / Service 0 12-13-2010 05:21 AM
