Old 12-23-2018, 01:08 AM   #1
EMT with a Yaris
Drives: 2010 Toyota Yaris - Sedan 4 Do
A/C Pressure Test/Diagnosing in cold ambient temps
Question is:
If the ambient temperature (car parked outside since I don't have a big enough garage to work in) is between 35-40 f (around 0-4c) what pressure should the car be having?
Service Manual states:
When the refrigerant volume is correct, the
gauge reading indicates as follows:
Low pressure side:
0.15 to 0.25 MPa (1.5 to 2.5 kgf/cm2)
High pressure side:
1.37 to 1.57 MPa (14 to 16 kgf/cm2)
HINT:
Pressure varies in accordance with certain
conditions (outside air temperature, sunlight
and wind).
EMT with a Yaris is offline   Reply With Quote
a/c, pressure
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
Help! A/C low pressure sensor..jumper? marcus Photo-Video-Media Gallery 12 07-18-2012 05:50 PM
A/C intermittently cold Wildcat DIY / Maintenance / Service 4 08-23-2010 03:21 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
