#1 |
Drives: 2006 Toyota Yaris T3 1.3 VVTi Join Date: Dec 2018
Squeaking Auxiliary Belt Under Load at Certain RPM?
Hi,
Newbie here, I have a 2006 XP90 1.3 VVTi Yaris, currently on 29k miles, which has recently started making an odd squeaky noise when accelerating from a low RPM. In any gear, when accelerating with over 50% throttle, between around 1000 to 2200 RPM, an odd squeaking noise can be heard like it is a slipping Auxiliary belt. If you accelerate through the noise it clears/fades out around 2200 RPM and the car drives perfectly normally with no misfires and pulls like it should. However, if this was the Auxiliary Belt slipping you would assume that it would do it at idle as well, which it doesn't, as the load of the Aux Belt would be constant due to Alternator/PS Pump/AC Pump drawing a constant load. I have also checked the tension of the belt, and tightened it to within Toyota Specs, and to no avail. The other odd thing is that is is very clearly engine load dependant because at very light throttle in the aforementioned RPM range the noise cannot be heard... Which would suggest to me that is is something else and not the Aux Belt?! Any help and suggestions would be greatly appreciated. Many Thanks. Charlie. |
| Tags |
| belt, engine, slipping, yaris, yaris 2006 |
| Blitz Supercharger Belt Slip @ Higher RPM? | Freestylin | Forced Induction Forum | 20 | 09-06-2017 08:32 AM |
| Auxiliary drive belt change | fredsyaris | DIY / Maintenance / Service | 0 | 06-30-2017 01:05 PM |
| 2008 Yaris Pings under low rpm and load | grimkeit | DIY / Maintenance / Service | 0 | 09-24-2015 02:16 AM |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 02:05 AM |
| IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 | RPM JEFF | Mid-Atlantic | 0 | 09-24-2012 04:10 PM |
