Old 02-06-2019, 10:07 AM   #1
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Help needed.
Could anyone with a factory head unit and reverse camera please help me. If you remove the plastic cover on the inside of the tailgate it will expose the camera position and cable. I took mine off and there is a open connector by the camera and I need to confirm if the camera is for that connection as it may be pre wired In to the 2013 Yaris. I have attached what it looks like. If you can could you also please see the code/part number on the camera and reply with it aswell.
Sent from my SM-A530F using Tapatalk
RicStyx is offline   Reply With Quote
Old 02-06-2019, 02:32 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I think you will find that connector is for the central locking if the car has a key lock in the back door.
Most likely a black wire and a blue wire. Grounding the black wire will lock the doors, and grounding the blue wire will unlock them.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 02-06-2019, 03:26 PM   #3
stykerdk
Yaris Hybrid Limited 2015
Take a look Here there is Good pics of the inside tailgate with reverse camera.
https://www.ebay.co.uk/itm/Toyota-Ya...QAAOSwEKxcWwOF
I Think you need this wiring loom.
https://www.ebay.co.uk/itm/TOYOTA-YA...4383.l4275.c20
C-HR 1,8 Hybrid premium 2020
Old 02-07-2019, 06:46 AM   #4
RicStyx
Yes I think you are right.
Old 02-07-2019, 06:55 AM   #5
RicStyx
The wiring loom looks correct, now im wondering if the head unit has the connector or not, ive had it out before but didn't take note to look. The Australian workbook states that you need a camera and a long wiring loom with new connector.
Old 02-07-2019, 10:36 AM   #6
stykerdk
I almost forgot toyotatech is your friend.
https://www.toyota-tech.eu/Aim/Aim2....AIM&menuitem=2
Looks like you need to buy a cable for the whole way from rear to head unit.
https://www.toyota-tech.eu/aimupload..._003_187_1.pdf
Old 02-07-2019, 12:31 PM   #7
RicStyx
I tried these but my local dealers can't pick the part numbers up
Old 02-07-2019, 12:42 PM   #8
stykerdk
Here and they ship worldwide.
https://sunparts24.de/en/PZ457B014000
Tools needed for MTM fifth gear R&R? 2009Toyotoad DIY / Maintenance / Service 5 06-21-2015 05:51 AM
Tail light LED replacement: mod needed? Yarflana DIY / Maintenance / Service 3 02-26-2013 10:46 PM
cost effective sensible mods help needed macguyver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-01-2012 10:21 AM
What is needed for coilovers justinparadise21 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 01-03-2009 12:53 AM
