Old 06-02-2007, 07:49 PM   #1
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Baby Moons
Made an adapter for baby moons (at least 1 wheel). The rest will be done within a week, and will paint wheels silver or charcoal....the beauty rings come last. Sorry about poor picture but I use what I got. 1st test drive stayed on well, but have to put a few miles on before completing the rest.
These are the larger size 9+ inches in diameter....the smaller under 8 inch diameter may look better, but these were cheap for a 1st try.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 06-02-2007, 08:53 PM   #2
hey good job! can you share a pic from a little further away, too?
Old 06-02-2007, 09:00 PM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
looks great,so far, no beauty rings?
SPONSORED BY
Old 06-02-2007, 09:08 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Now for some 2" wide whites and you're set!
Old 06-02-2007, 09:41 PM   #5
brickhardmeat
Lonesome Cowboy
can white walls be had these days?
SPONSORED BY
Old 06-02-2007, 10:00 PM   #6
Chris07LB
Chris07LB's Avatar
heck yea they can.. from all the old school sizes, all the way up to 24".
Old 06-02-2007, 10:25 PM   #7
brickhardmeat
Lonesome Cowboy
I saw this guy in a hoopty with wire wheels and either shoe polish or a really bad spray paint job on his tires, he was trying to pull off a wide white wall but man was it a mess
from a good distance I thought they were for real but the closer I got the more you could see what a big damn mess he made
SPONSORED BY
Old 06-02-2007, 11:16 PM   #8
churp
churp's Avatar
Have only the one wheel mounted so lookin a little odd.....but driven about 50 miles with a burst up to 90 to check the adapter. Won't have the other 3 done till sometime next week. Will paint the rims tomorrow then should have pictures posted by mid week.
Contemplating the wide whites but Coker Tire wants $170 apiece. May try one of the tire paints, but like Brick say's ....awfull easy to end up with crap.
____________
Old 06-03-2007, 11:27 AM   #9
Chris07LB
Chris07LB's Avatar
Unless you are sanding all the letters and numbers off of your original tires, then dont go the painted route.
Ive seen it done in person before, and as long as all that craps removed first, you would never know they were painted 'whites.
Old 06-03-2007, 09:16 PM   #10
churp
churp's Avatar
Pic's just taken. one with the painted wheel and adapter brakets shown, and 2 others showing the whole car...still with stock hubcap on rear. Beauty rings may improve the looks but no cash now. IMO much better than stock...look like early european??
____________
Old 06-03-2007, 09:22 PM   #11
brickhardmeat
Lonesome Cowboy
damn sweet looking job!
that looks great. if you put a beauty ring on that then I will be very jealous, that looks perfect, don't even need a white wall
you could make some money selling those adapters
SPONSORED BY
Old 06-03-2007, 10:04 PM   #12
kurokoma-kun
Drives: 2007 Yaris HB
wow, nice results! looks sweet on silver steelies
so you made adaptor bracket from what, aluminum? how did you attach each bracket to center ring that fits around steelie hub? what about ring itself? tools required? how much to make (in money and time)?
sorry, so many ?s... i just really like this kind of cheap clever mod...
Old 06-03-2007, 10:34 PM   #13
brickhardmeat
Lonesome Cowboy
so are we dubbing churp the first official rat rod yaris?
SPONSORED BY
Old 06-03-2007, 11:05 PM   #14
churp
churp's Avatar
Had a different idea at first but ended up cheap and dirty......1/8" X 1" hot rolled steel (softer and easier to work with than cold rolled). Cut it 4.5" long and drilled a 5/8" hole 1" from the ends. I ground the short end so the wheel stud was centered, yet the end butted up against the center of the wheel....this was to keep each of the 4 brackets locked in place with the lug nut tightened (4 pieces/wheel is good enough for me but anything production should be a 1 piece). The bends on these were done by hammering and using any hard object available for an anvil.....the next 3 wheels will be much easier at work with proper bending equipment. The 5/8" hole is a little small, but mushrooms out enough (thanks to the hot rolled, possibly aluminum would work better as long as it's tempered enough to hold its shape but not to much to bend!). I have over 150 miles on so far and haven't had a problem with this wheel, and don't think I will.
If anyone does do this try to get the smaller (old chrysler products) 7+" diameter moons, I think they would look better because they would sit inside the wheel 'dish'. The 9+" ones I'm putting on, stick out from the wheel quite a ways, and looked a little odd from the front or rear at first but I'm getting more used to it.....just not a look that everyone would like!
____________
Old 06-04-2007, 04:10 PM   #15
kurokoma-kun
[SIGPIC][/SIGPIC]
Old 06-04-2007, 04:51 PM   #16
brickhardmeat
Lonesome Cowboy
f-i-n-k
SPONSORED BY
Old 06-05-2007, 12:08 AM   #17
redyaris
Shiny Chromey Coolness
redyaris's Avatar
This is pretty sweet...european 1940esque!!!
Spun Baby Moons? blacksan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 05-16-2009 12:51 PM
baby strollers in boot of HB wushumasterku General Yaris / Vitz Discussion 13 03-25-2007 10:32 AM
YEAH YEAH...I Brought new HID for my baby!!!! iloveyarisRS Cosmetic Modifications (Exterior/Interior) 29 12-23-2006 03:27 PM
My new baby coming off the production line today frikkie New YARIS Purchase Forum 9 12-09-2006 12:04 AM
Port A Walls tomjasz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 09-04-2006 05:20 PM
