#1 |
![]() Drives: 2008 Toyota Yaris Join Date: Feb 2019
Rear Striker Lost a Bolt
Hey everyone, I bought a 2008 Yaris manual with 126k miles a few weeks ago. The rear hatch striker is completely loose. The striker is the name for the thing that the latch grabs when the hatch closes. When I took everything apart, the right bolt for the striker was completely missing. I unscrewed the remaining bolt and noticed that the thing the striker is supposed to screw into looks like it has a section snapped off. I can probably replace them with some other nuts and bolts but I like to try and keep original parts if possible. I am considering just going to a junk yard and taking the rear striker apart and taking whatever the striker bolts screw into. I searched all over for a part number for what I am looking for and couldn't find it. Any recommendations?
Attached is an image of the pieces. |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Just as you said... junk yard is probably your best bet. Toyota will probably want crazy money for that.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
#3 |
![]() ![]() ![]() Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
Junk yard and 2007-2011 will work for sure, other years may also be the same
#4 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
I think you might be able to get away with popping in another rivnut with a corresponding bolt.
#5 |
I want to update this in case anyone ever runs into a similar problem. I am still waiting to head to a junk yard to get another screw but it's not high on my list of priorities because I have my one screw and nut holding the striker on. I did it by placing the nut in the "closed" box side of a wrench and sticking it in the holes in the rear metal until its below where the striker goes. It takes a few tries but eventually you can get it. Hopefully the pics help explain what I mean. I'm sure you don't have to use the screws and nuts that came with the car, I just wanted to. I found the part number pretty easily for the screw, and they were cheap even from Toyota (<$2). I just want other things from the junkyard anyways so I am not ordering new. Also that little part of the nut that juts out I think helps it grab and stay in place so I wanted to use the real ones.
I am pretty sure this issue is never supposed to happen and those nuts are supposed to be welded on, mine just broke somehow. I even went to the dealership to ask them if there is a part number for the nut and he told me they are part of the frame and he has no idea how they came loose. |
#6 |
Drives: 2007 Toyota Yaris Join Date: Dec 2020
Thanks jayis, this helped me fix my striker.
#7 | |
![]() ![]() Drives: 07 AT & 08 MT Yaris HB 3dr Join Date: Nov 2021
https://www.yarisworld.com/forums/sh...165#post843165 |
| Rear brake disks sliding bolt torque | Keymaster | DIY / Maintenance / Service | 6 | 04-12-2016 03:53 AM |
| How to set up rear window wash sprayer? | Be_Jammin | DIY / Maintenance / Service | 0 | 03-13-2016 05:40 PM |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
