Old 02-13-2019, 10:12 PM   #1
charliegriefer
Drives: 2010 Yaris
Screwed up my cluster. Help?
Hey all...
So, I wanted to modify the LEDs in the cluster on my daughter's 2010. I was told by an acquaintance that the LEDs are just plug and play. As most of you probably know, this is incorrect.
However, I bought some (incorrect) LEDs off of Amazon, and removed the cluster tonight. Upon seeing that the bulbs actually need some soldering (something that I am not prepared to undertake), I put everything back together.
Unfortunately, the area that shows the fuel level/gear/trip odometer, while lit up, is blank (see attachment). Also, the speedometer needle no longer moves.
I disassembled it all again and put it back together (the functional equivalent of turning it off and turning it back on again), but to no avail.
So, before I continue taking it apart and putting it back together in the hopes that it will magically work... I was hoping that somebody smarter than me (which would be anybody reading this) might know something specific that I should be looking for/at.
Otherwise, I suppose I'm headed to the dealership to plead stupidity and empty my wallet :\
Any help would be _greatly_ appreciated.
Thanks!
Charlie
charliegriefer is offline   Reply With Quote
Old 02-14-2019, 05:21 AM   #2
bob225
I take it is all securely pluged back in, did you disconnect the battery before removing the cluster ?
It could of just lost communication with the ecu, disconect the battery for 15-20 mins and let the ecu and bcm reset
bob225 is offline   Reply With Quote
Old 02-14-2019, 12:26 PM   #3
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Yeah I swapped mine for an S cluster and I think the battery disconnect is your fix.
firebird1999us is offline   Reply With Quote
Old 02-14-2019, 03:34 PM   #4
charliegriefer
Drives: 2010 Yaris
Thanks, folks! Will disconnect the battery when she gets home from school and see how that goes.
Old 02-14-2019, 08:26 PM   #5
charliegriefer
Drives: 2010 Yaris
Battery disconnect didn't do it, unfortunately.
Took it apart again. Noticed a few pins (16 or so) behind the display. I don't believe that all of those pins were connected. In fact, a couple were bent. Carefully straightened 'em, ensured they were all connected, and now we're good.
Well, mostly. Speedometer needle's off a bit. Will have to adjust that. But yeah... I just hadn't reassembled everything properly :\
3rd Gen Gauge Cluster Swap :D KenTK808 Third Gen Yaris General Discussion 22 10-21-2017 07:58 AM
Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback AndyW Willing to Buy by private party 6 12-07-2014 08:53 PM
Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS Jabro Willing to Buy by private party 4 12-21-2012 06:34 PM
HB GAUGE CLUSTER WITH RPM $125 TURBO YARIS Items for Sale by private party 17 12-12-2011 06:44 PM
FS: Gauge Cluster from '09 LB- $150 MGargano Items for Sale by private party 14 10-05-2009 12:59 PM
