Old 02-24-2019, 09:01 AM   #1
Robmorgan
Drives: Mk1 1.3vvti
Rear brake line replacement
Hi all,
This is my first post on here 😁
I've bought a mk1 1.3vvti for my son as his first car.
It failed the mot on front drop links and rear brake lines.
I am trying to remove the solid brake line so I can renew it all. But I can't see the brackets behind the fuel tank. How does it release? Do I need to remove the fuel tank? I've lowered it as much as I can on the bolts that hold it in place, but I'm stuck now.
Help please!
Robmorgan is offline   Reply With Quote
Old 02-24-2019, 05:03 PM   #2
2bz
Drives: 2008 Yaris 3DR Hatch MT
Here's the service manual. Start reading at page BR-68.......
https://cardiagn.com/brake-2007-yaris/
2bz is offline   Reply With Quote
Old 02-24-2019, 06:36 PM   #3
Robmorgan
Drives: Mk1 1.3vvti
Thanks. But that didn't go into detail about removing the hard lines. I ended up removing all 4 bolts that hold the fuel tank in anyway. Luckily, there was only around 5-10 litres in the tank. I have removed the lines now. Just need to get new ones made up, so I can refit ��
Need rear brake help! Star wheel/spring combo won't reattach msapocalypse DIY / Maintenance / Service 0 10-08-2016 06:19 PM
Yaris with rear disc brake from factory? tamrat DIY / Maintenance / Service 18 01-19-2016 09:08 AM
Rear brake adjustment compnovo DIY / Maintenance / Service 2 06-25-2014 10:06 PM
Yaris Rear Driving Lights Problem ap222 DIY / Maintenance / Service 3 05-31-2013 05:49 PM
