Old 03-03-2019, 01:52 PM   #1
Kartingalan
Drives: 2005 Yaris
Engine light on code P1345
Engine light won’t go out - at first the initial code said fault crank sensor, light still on. Next code said cam sensor, light still on. Then code P1345 said VVT sensor. Replaced it (albeit with cheap Chinese part) - engine light still on and comes up with same code.
Car runs well at all revs including idle!
Any ideas would be welcome
Al
Kartingalan is offline   Reply With Quote
Old 03-03-2019, 03:35 PM   #2
Have you actually performed a code reset, or just hoping they will go away because you dealt with the issues?
Sent from my EML-L09 using Tapatalk
Old 03-04-2019, 05:55 PM   #3
Kartingalan
Drives: 2005 Yaris
Yes I have re set the engine codes
SRS Light On (B1805/52 Code) Even after having recalls done fourbangingfun DIY / Maintenance / Service 3 10-07-2017 11:48 PM
Engine light came on but seems to run fine naossoan DIY / Maintenance / Service 7 06-10-2013 04:51 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
