Old 03-23-2019, 05:28 PM   #1
BartSimpson
Drives: Yaris 2003
Water in the boot
Hello everyone,
I have seen some similar posts, but my case looks slightly different. This is why I am opening a new topic.
I have a leak in my trunk. I found it out when Iooked under the boot floor cover - there was water in the spare tire bay and the left side of the floor mat was wet. I replaced the left taillight gasket.
It does not leak that much now, but the problem persists. It does not leak from the under. There is a sunroof, but I do not think it leaks through there.
It leaks only when I use a hose and spill the water on the hatch.
The hatch has 2 metal sheets welded from inside - it somehow leaks through there.
https://www.youtube.com/watch?v=yHLlXxZCwgg
Any ideas? Change the taillight seal one more time?
Thank you,
Bart
BartSimpson is offline   Reply With Quote
Old 03-23-2019, 05:43 PM   #2
Could be from the glass, or the boot "door" seal? Not sure where you are hosing down from.
Sent from my CLT-L04 using Tapatalk
Old 03-23-2019, 06:53 PM   #3
2bz
Drives: 2008 Yaris 3DR Hatch MT
No different than the other 200 posts about leaks. Everybody's Yaris leaks. If you want a Yaris that doesn't leak buy a Fit. Welcome to the club.
2bz is offline   Reply With Quote
Old 03-23-2019, 08:33 PM   #4
dogsridewith
Drives: 2007 2-door hatchback
Tail light gasket
The tail light gasket may have relaxed. Only two nuts on one side snug it down...it needs at least three. I nearly eliminated major leakage both sides just by cleaning up everything and re-using original gaskets (No sealant added, but I MIGHT have lightly greased them...which I'm not recommending)
Check the nuts. My sense is that it is better not to squeeze the crap out of a brand new gasket, but rather snug it down incrementally over time.
Old 03-24-2019, 10:20 AM   #5
myfirstyota
3 Yaris and counting..
Basically the only downfall of this car. Leaky McLeakerson
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 03-24-2019, 10:58 AM   #6
BartSimpson
Drives: Yaris 2003
Hi guys,
I have already removed the tail light, cleaned it and applied silicone on the original gasket.
When I spill the water directly on the rear light it does not leak. It leaks when I spill the water above the rear light, at the top of the hatch.
In your case, when the leak was from the tail light - where did the water come out? Was it clear the leak is from the lights?
Old 03-24-2019, 12:21 PM   #7
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
Originally Posted by BartSimpson View Post
Hi guys,
Run a silicone bead between the light and the car so you seal up the gap. This will guide the water away
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 03-24-2019, 03:32 PM   #8
2bz
Make new tail light gaskets. Use this:
https://www.michaels.com/creatology-...M10390268.html
Old 03-24-2019, 04:23 PM   #9
dogsridewith
Yaris hatch leak tail light
There is a joint in the overlapping spot welded tin where the gutter dumps rearward (above the taillights). I also cleaned up that area when I did the taillight gasket...but didn't add caulk or anything up there. The gutters themselves are smooth and crack free.
I still get dripping from the hatch raised some time after a rain, as if water got into it...starting to wonder about small shields at hatch top corners trapping water and letting it into the hatch through the holes for the clips.
Water leak/removing rear seats Sarah1986 DIY / Maintenance / Service 1 12-12-2016 06:38 AM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
water in the tails? the_boss Cosmetic Modifications (Exterior/Interior) 9 02-20-2009 12:53 PM
Shift Boot ... revisited bigsky2 Cosmetic Modifications (Exterior/Interior) 35 04-19-2007 07:04 AM
