Old 03-23-2019, 08:39 PM   #1
Brettguy
Drives: 5 spd MT,black ASA iwheels
Preventative maintenance or run it till it sounds bad?
just wondering what the general consensus is around here, whats been your strategy? Any surprise part failures for anyone here?
im at 160k on the clock with a couple squeaks here and there but my 07 hb runs like hell otherwise
next parts on my watch list are:
alternator
water pump
engine mounts
fuel pump
fuel filter
im stuck on this topic since i wanna keep this car forever (plus im broke )
Brettguy is offline   Reply With Quote
Old 03-24-2019, 09:12 AM   #2
Leegamer
Leegamer's Avatar
I mean preventative is definitely the way to go if you can.
Some things fail unexpectedly, but basic maintenance should be kept up as best as possible.
I'm a hermit named Lee
Old 03-24-2019, 09:18 AM   #3
Nothing to do on your "watch" list. These things fail when they do.
Preventive maintenance would be checking axle boots for cracks/leaks, oil pan rust, timing chain cover leak, sway bar bushings, cleaning throttle body, etc.
Sent from my CLT-L04 using Tapatalk
Old 03-24-2019, 10:13 AM   #4
myfirstyota
3 Yaris and counting..
Oil and air filters, spark plugs, tire pressure, rear drum adjustment, etc. With these newfangled engines, computer controls and all that, tune ups are pretty simple now. But at 160,000miles, you're long due for spark plugs if they've never been changed.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Preventative Maintenance tmontague DIY / Maintenance / Service 20 11-05-2014 12:22 PM
Bad sounds. sheraz2000 General Yaris / Vitz Discussion 18 02-23-2009 06:29 PM
