Old 03-30-2019, 02:29 AM   #1
avi
Drives: Yaris 2012
Check engine & tsc lights on after jump starting
Hi
The battery of my 2012 Yaris went belly up (it's the original battery, unbelievable) so I've jump strated it from another vehicle and to my surprise, the "check engine" and "tsc" went on/ the only thing that I did, was to push manually the Yaris so that it will be close enough to the other vehicle that I've jump started from. is there an explanation for it? and the second thing that I would like to ask - how can I reset these alerts - without a scanner, of course?
avi is offline   Reply With Quote
Old 03-30-2019, 03:37 PM   #2
komichal
I would be quite curious about the error code thrown. Are you sure you do not want to spend some 8 USD on OBD2 BT module? Sooner or later you will need it, trust me.
And of course you can erase the code with it easily.
Old 03-30-2019, 10:35 PM   #3
avi
Drives: Yaris 2012
Are you referring to the gadget sold on Aliexpress, for example? didn't knew that they can do it. I thought they they only can display "fancy" data that there is on the instrument panel already. I'll get one. any idea what could have caused the faults?
Old 03-31-2019, 05:45 PM   #4
You should get the codes, then it will tell you what's going on.
Sent from my CLT-L04 using Tapatalk
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
