Old 04-14-2019, 03:40 AM   #1
robyav
Drives: echo
Toyota Echo automatic 2004 Engine damaged
Greeting to all.
I have a question which i am unable to find any answers .i hope i could get some here .Recently my echo engine (with automatic gearbox)got damaged by broken valve , broken piston and head .
so i took it to the mechanic ,he said its much cheap to replace the whole engine with the same engine from the scrapped car .So i finally found one after a long search as echo is getting rarer ,but the problem is that it is scrapped echo is with a Manual gearbox .will this engine be a correct fit to my automatic gearbox ?
regards
roby
robyav is offline   Reply With Quote
Old 04-14-2019, 08:16 AM   #2
The engine block is the same from 1999 to 2018 wether it is automatic or manual.
You just need to keep all your accessories, transmission, intake manifold and exhaust manifold depending on the year you get. Because, a Yaris manifold will not fit..
Sent from my CLT-L04 using Tapatalk
2003 Yaris 1.3 engine swap help Jedi4690 DIY / Maintenance / Service 0 03-27-2018 04:08 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 02:01 AM
GT5 Gran Turismo 5 Bluevitz-rs Off-topic / Other Cars / Everything else Discussions 144 03-04-2011 10:13 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 01:57 PM
engine swap update Adriaan Canada 5 03-03-2009 07:21 PM
