Old 05-10-2019, 09:03 AM   #1
Tskm2
Drives: Yaris hatchback 06
Diffrence front/back track width
Whats the mm diffrence? After a quick look with my stock winter wheel they have only a 1/4in diffrence tire/fender. But most people pit penguin spacer at 10 or 12/13mm...
I buy used wheel in 15x7 et25. I just install one in front and its flush to fender and i want the same for the rear
What size spacer did you put
Tskm2 is offline   Reply With Quote
Old 05-11-2019, 06:22 AM   #2
myfirstyota
3 Yaris and counting..
Install the wheel on the back and measure from rim to fender. That will give you your desired spacer width.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
May 20th Longwkend Monday Mosport DDT track event 10:30 - 5pm #5 Touge.ca event Touge.ca Canada 0 05-08-2019 09:33 PM
October 8th Longwkend Monday Mosport DDT track event 10:30 - 5pm #24 Touge.ca event Touge.ca Canada 0 10-04-2018 12:13 AM
May 22nd Longwkend Monday Mosport DDT track event 10:30 - 5pm #5 Touge.ca event Touge.ca Canada 0 05-09-2017 01:37 AM
May 23-Victoria Longwkend Monday Mosport DDT track event 10:30-5pm #6 Touge.ca event! Touge.ca Canada 0 05-05-2016 02:54 AM
