Old 05-13-2019, 06:15 PM   #1
Jeffbass
Drives: 2010 Yaris
Cv axle play at auto transmission leading me towards trans swap
So I was hearing some clunking when parking or leaving a spot where the wheel was turned hard. I figured it was the cv axles so I replaced both still had a lot of play it has now gotten even worse, so I have been looking into changing the transmission for a low mileage junk yard one. Was wondering if I am on the right track with a trans swap as my only good option or can the differential guts be worked on with it in the car? I have also been looking at dropping the trans and it looks like it will come straight down without removing the subframe. Has anyone had success with this? I can’t seem to find much in the way of a Yaris trans swap online and don’t really have the means to pull the engine and trans in one piece and I am also trying to keep from opening the ac system. Anyone know of a good write up, video or manual. Thanks in advance
Jeffbass is offline   Reply With Quote
TRD Delrin Rear Axle Bushing Collars tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2019 07:50 PM
Is there a difference in cv axles for auto and manual transmission? Yaris709 DIY / Maintenance / Service 4 08-06-2017 08:30 AM
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
Any vendors on Yarisworld sell Auto Transmission pans? detroiter General Yaris / Vitz Discussion 5 02-25-2009 10:47 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
