Old 05-19-2019, 01:07 PM   #1
YarisX
Drives: 2009 Toyota Yaris Hatchback
2009 Yaris Hatchback Trunk leak
I wanted to post my discovery somewhere since I have been trying to resolve a leak in the trunk of my Yaris for about two months. I tried everything I could find only to discover water still getting in the vehicle. I managed to plug a few minor leaks along the way but wasn't able to find the king of the leaks till today.
I removed the bumper cover from my car thinking that I was still dealing the a hatch seal issue. As I was spraying the back end of the car under the bumper I noticed a ridiculous amount of water getting in even though the water wasn't hitting the hatch seal. Turns out there is a seam a few inches below the tail light that had separated a lot on mine.
I haven't seen any information anywhere on the internet so I wanted to throw the problem up on here. If you have a mystery leak that you can't seem to pinpoint this might be your issue. I'll keep an eye on this post in case anyone runs into the same problem. I don't want anyone to ride the struggle bus I've been on for two months. I'll post pictures if anyone needs help locating the suspect area. I'll also be keeping an eye on this because I think I now know every possible leak in the back of 2009 Yaris Hatchback.
Closing thoughts, Toyota did a horrible job on the back end of this car.
"A Wizard should know better!"
YarisX is offline   Reply With Quote
hatch, hatchback, leak, seam, yaris
2010 Yaris Liftback (LB) / Hatchback - Prewired for Trunk Actuator? bad_bwoy007 DIY / Maintenance / Service 26 01-18-2021 06:09 AM
2008 Yaris, Hatchback - Both rear brake/combo light assys leak beowulf DIY / Maintenance / Service 0 05-18-2018 07:41 PM
For Sale 2009 Sport Yaris Hatchback!!!!! marinos9000 New England 2 04-24-2010 03:09 AM
