Old 06-05-2019, 03:33 PM   #1
komichal
Ambient temperature sensor
Hi fams,
now when the temperatures went up here in Central Europe, I have noticed some strange behavior of the outer temperature indicator.
It has never been a fast one (last summer when I drove away from the underground parking spot where was 19 degrees Celsius to outside where was 30 degrees, it took usually some 5 minutes for the temperature to show the right number).
But this time it is a lot worse... I am driving at 30 degrees and even after 20 minutes the temperature indication goes up from 19 degrees to 23 for example. Quick visual inspection through the front bumper showed no peculiarities or dirt or anything so I guess it is time to replace the sensor as the first step to take.
I found the part ID (88790-22131) and now I am wondering whether I should be fine with 15 USD for cheap Chinese product or whether I should pay 35 USD for the original Toyota part.
I assume that inside that plastic thing there is just a NTC thermistor or something like that so - unlike MAF for example - there is not much that the Chinese worker could screw. Still... what would you go for?
Thank you!
Old 07-09-2019, 05:08 AM   #2
toyotavios_11
Drives: Toyota Vios
USD35 and USD15, not much different for me, would go for original part
toyotavios_11 is offline   Reply With Quote
Old 07-10-2019, 12:57 AM   #3
komichal
I did in the end. :)
Now I only need time to tear that bumper off and replace the sensor....
Outside (ambient) Temperature Sensor Amilch DIY / Maintenance / Service 4 12-29-2018 01:03 PM
Ambient temperature sensor OBD-II data spookybathtub In Car Entertainment + Electronics (audio / video / alarm) 15 03-23-2015 12:21 PM
Automatic A/C: Ambient sensor airflow? dj92 DIY / Maintenance / Service 9 01-09-2015 03:53 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
