Old 06-19-2019, 07:26 AM   #1
stefantomic
Drives: Toyota Yaris
Cranking sound on cold start / Yaris 2009 1.33 VVT-i
So I have this problem only on cold start. Car produces weird cranking sound for like 2 seconds and then it disappears. I have 2 cold start videos that I recorded in a different period of time. Does anyone know what's the issue? Thanks!
Here are the videos - https://photos.app.goo.gl/MFW3iwYd3wtyW5bV7
stefantomic is offline   Reply With Quote
Old 06-19-2019, 06:12 PM   #2
zoidberg444
zoidberg444's Avatar
Shit. That doesn't sound good. You know i almost wonder if the starter cog is sticking out and grinding on the flex plate when you are starting.
Sent from my SM-G965F using Tapatalk
UK to Nordkapp in a Yaris
Old 06-19-2019, 10:02 PM   #3
Pull your starter first and check the teeth and the teeth in your flex plate/flywheel(?)
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 06:19 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
07 yaris lb sometimes does not start :( biggyjiggy DIY / Maintenance / Service 10 07-09-2012 05:59 PM
