Old 07-14-2019, 10:56 PM   #1
bluefever00
Drives: 2008 Sedan
Camera wiring
Would anyone happen to know which wire to tap into for ignition on to wire up a camera? All the posts i've seen on here talk about tapping into the backup light power.
bluefever00 is offline   Reply With Quote
Old 07-17-2019, 11:32 PM   #2
SirDigby
Drives: 2007 yaris 3 door
no. why back up lights? they are only on when you back up. i would tap into the rear wiper circuit or the cig power port. both have 15a circuits. or the acc. circuit. it is at 7.5a
Old 07-21-2019, 03:46 AM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Reversing camera or Dash camera?
Taking power from the reverse lights is a simple method to pwer a reversiong camera, as you only want it to turn on when reverse gear is selected. For a dash camera, you wa t pwer whenever the engine is running.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 09-16-2019, 06:04 PM   #4
bluefever00
Drives: 2008 Sedan
My Yaris is an automatic, where should i tap into for the trigger wire to turn the camera on?
