#1 |
![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
2007 Yaris O2 sensor removal
Hi I changed out O2 sensor with a new denso. Ran to get exhaust hot. Removed with kroil penetrating oil / lisle O2 socket - Armstrong 11 inch long 11-994 locking 3/8 flex head ratchet. Installed with gearwrench 120 3/8 ratchet . Final 1/4 turn to 44 nm with a 22mm proto crowfoot and a flex head gearwrench 3/8 torque wrench. I didn’t remove cv boot guard. No pics apparently they are too big for Yaris world computer
Denso socket
#3 |
Gearwrench 3/8’120xp on lisle dual drive o2 socket. Fine tooth made room to swing.
#4 |
Shield for cv boot that I didn’t remove. Gearwrench 120 in upper left
#5 |
Lisle dual drive o2 sensor
#6 |
Proto 22mm crowfoot
#7 |
The sensor connection
#8 |
The sensor connection is behind this white box
#9 |
The reason I didn’t remove boot shield is because I couldn’t see but only could feell fasteners . I was on my back , Yaris on ramps , head first sliding under from front. If I skid under feet first maybe I could of saw but/bolt holding shield. I actually had fun leaving it on and working around it with a fine tooth ratchet .
#10 |
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
i remove it from top, first need to remove battery for more room of access
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
| 2007 and up Yaris Sedan S | McDizzle | New YARIS Purchase Forum | 3 | 12-03-2009 01:42 PM |
