Old 08-04-2019, 08:24 AM   #1
Brettguy
Drives: 5 spd MT,black ASA iwheels
Finally did my water pump
Slogged through 8 hrs of finagling and massaging parts parts loose yesterday and got it done
Observations: this is the most cramped space ive ever worked on. I couldn't get enough space to fit my 3/8 torque wrench with a 1/4 in adapter in order to torque down the pumps side bolts to their 8-11ft lb range so I just went "real tight" with a 10mm wrench,
if I were to do this again again I'd buy:
1/4 in torque wrench
Stubby ratcheting wrenches
Shallow 10,12mm sockets
Questions remain:
Car only took ~4.4 quarts out of the 5.1 stated, I've burped and refilled with a regular funnel about 5 times and everything seems well, though spilling an annoying amount each time
Is checking the level on the expansion tank the best way for checking for a slow leak?
If my temps were normal during a 50 mile hwy run then can I assume it's properly bled?
Did I screw myself by not using a torque wrench?
Sent from my SM-N910T using Tapatalk
Brettguy is offline   Reply With Quote
Why the water pump went on my 2009 a theory bronsin General Yaris / Vitz Discussion 19 08-06-2018 12:45 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
