Old 08-09-2019, 02:12 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
radiator
I did a flush on my 1.5 radiator. It was running hot. It is only taking about half of the 5 qts
new stuff
its supposed to...?? any ideas??
yaris9876 is offline   Reply With Quote
Old 08-09-2019, 03:04 PM   #2
alanwagen
Well there is a drain cock on the engine as well as you have some antifreeze in your heater core.
Old 08-09-2019, 06:41 PM   #3
zoidberg444
zoidberg444's Avatar
Yes. Not sure where it is on the 1.5 but on the 1.0 Yaris there is a drain underneath the water pump. When i changed the coolant on mine a few years ago i think between the radiator and the drain on the engine i got about 4.5L out.
Sent from my SM-G965F using Tapatalk
UK to Nordkapp in a Yaris
Old 08-09-2019, 09:16 PM   #4
yaris9876
I didnt know about the engine drain plug. Where is it exactly on the 2007 1.5?any pics?
Because I failed to get all the coolant out I have 2 quarts of water and 2 quarts of 50/50 coolant in there.
Thats only 25% of the coolant needed. At the least I will drain 2 quarts from the radiator and put in 2 quarts of 100% coolant and that should work. But I would like to drain the block..
How to replace the radiator - guide tmontague DIY / Maintenance / Service 10 02-20-2023 11:18 AM
!st gen pontiac vibe/toyota matrix dual core radiator install tmontague Performance Modifications 5 05-01-2019 09:31 PM
Radiator Cap - 1.1 bar or 0.9? NorthernGirl General Yaris / Vitz Discussion 11 12-29-2018 08:27 AM
Radiator Fan not working.. Beubeu DIY / Maintenance / Service 3 09-21-2015 12:53 PM
Radiator Change TMR3 DIY / Maintenance / Service 5 06-22-2012 12:11 PM
