#1 |
QCyaris
picked myself up a 2007 yaris while i was back in Ontario visiting family for a couple weeks...dragged it back to GR. it needs a bit of TLC, but it has a special surprise under-hood.
![]() ![]() ![]() ![]() ![]() ![]() hanging out with the #wrecho ![]() while i was in Ontario i went to a couple of u-pull wreckers and got a bunch of pieces to replace the HU and the airbag-less steering wheel. thanks to crankyoldman for the HU brackets! ![]()
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Niiiiiice. What engine has she got? 1NZ? 5 speed manual?
Sent from my SM-G965F using Tapatalk
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#3 |
Yup, 1nzfe 1.5L 5 speed manual
#4 |
feed my pet
#5 |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Assuming you got a decent deal, the cost was probably worth it just to get the SC
I'm a hermit named Lee |
#6 |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Cars with much less mileage can be had for about $3000 in this part of Ontario. He probably scored a wicked deal!
My first yaris was bought for $3200cad with 114,000km. Second (blue one I'm lifting) for $2500 with 160,000km The 2zr swapped car for $3100 with 139 on the odometer. Granted this is an RS model that was in good shape with no rust.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
#7 |
God I hope that S/C is in good shape. I'd personally be nervous picking up a Blitz these days. Most of the ones floating around are 10 years +/- old now. Is this vehicle previously known to YW?
#8 | |
Biggest issue removing it is seized bolts..
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Wow, what an awesome and rare find! Congrats.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ |
#10 |
![]() Drives: 2010 Yaris Hatchback Join Date: Jun 2019
Impressive car you have there.
#11 |
Follow what’s going on at https://www.facebook.com/projectwrecho/
#12 |
Thanks for the link.
