Old 08-23-2019, 03:50 PM   #1
imopxn
Drives: 2010 Toyota Yaris Sedan
Brake caliper torque specs?
Hello all,
This is my first time changing the rotors and brake pads on my 2010 Yaris sedan. How would I find the correct torque specs for each bolt on the caliper?
imopxn is offline   Reply With Quote
Old 08-23-2019, 04:33 PM   #2
myfirstyota
3 Yaris and counting..
Calibrated elbow. Not too tight! Lol
I honestly dont know. I'm sure someone here does. I've always just estimated. Hasn't failed me yet!
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 08-23-2019, 07:08 PM   #3
johnwk
Drives: 2010 Yaris LB
According to the Haynes Manual, the spec for the guide pin bolt is 34 Nm (25 ft lbs) and the spec for the caliper mounting bracket bolts is 107 Nm (79 ft lbs).
johnwk is offline   Reply With Quote
Old 08-23-2019, 11:08 PM   #4
ex-x-fire
I'd use some blue Loctite too.
Old 08-24-2019, 08:18 AM   #5
Hmm good to know, I've always went with a couple ugga dugga's (SMA reference) on the 14mm caliper slide pin bolts and a few on th 17mm bracket bolts. Never had an issue in the track yet.
Old 08-26-2019, 02:13 AM   #6
komichal
Yep, I am using these values as well. Works fine. No Loctite on threads. Waste of money (unless you have it for free).
Rear brake disks sliding bolt torque Keymaster DIY / Maintenance / Service 6 04-12-2016 03:53 AM
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 03:36 PM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
