Old 09-03-2019, 05:32 AM   #1
ojeysky
Drives: Sedan Yaris 2010
Grinding noise at low speed Trac ABS light blinking
Hello,
My LH abs cable was faulty and I got a replacement, I also replaced my steering rack (which meant I had to disconnect battery for a long time during the rack replacement).
I have now noticed that when I drive I suddenly get a grinding noise even at low speed, during this period the car brake pedal pushes back and the the trac light blinks I am usually force to park. However if I then disconnect the abs sensor cable, I get the airbag and trac light on permanently but the grinding no longer happens. Though I get some little scratching sound when I apply brakes occasionally.
How do I fix this please? And is it okay to continue to drive with trac and airbag lights on?
ojeysky is offline   Reply With Quote
Old 09-04-2019, 11:44 AM   #2
ojeysky
Bump
Low road noise in Yaris? RedRide General Yaris / Vitz Discussion 32 05-30-2010 08:49 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
DIY for Low Cost Dim Light in the light LED tang DIY / Maintenance / Service 0 03-08-2009 10:58 PM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
