Old 09-06-2019, 10:38 AM   #1
Paisley777
Drives: 09 Yaris
Constant beeping ~after~ oil change
***UPDATE***
While the oil pan was draining I was cleaning up in the car.
Went to Oreily and the codes are B1650 & B1826 - Occupant classification system malfunction & Open in side squib (right) circuit
So... new question... How do I shut this thing UP?
Hello,
New one for me.
Car needed an oil change so it went through the normal flashes at start, then to solid maintenance light - but otherwise all good.
(not my first oil change with this car btw)
changed the oil.
Now when it beeps endlessly! No leaks from pan nut or filter. Oil levels look good. (always harder to see right after with that clean oil)
Notes:
spilled a bit when pouring in the new. Cleaned up and used some break cleaner on the belt to stop the squeaking.
Why is it doing this?
Thanks
Paisley777 is offline   Reply With Quote
Old 09-06-2019, 10:49 AM   #2
Leegamer
Leegamer's Avatar
Can you record the beeping? The only beeping I'm aware of it for the seat belts.
I'm a hermit named Lee
Old 09-06-2019, 04:07 PM   #3
Paisley777
Drives: 09 Yaris
You're not wrong:
Update:
Any idea how to shut this up?!
Old 09-06-2019, 06:36 PM   #4
Brighton
Knower of little
Drives: None
I'm not sure why it's doing that but I'd suspect those two things are not related (oil pan =/= start beeping) I'd think maybe one of the connectors under the seat got disconnected or something else. I can't imagine anything under the hood being related to that system other than the crash/g force sensors
Brighton is offline   Reply With Quote
Old 09-06-2019, 09:23 PM   #5
johnwk
Drives: 2010 Yaris LB
Long shot: Did you pull the emergency brake while cleaning?
Or is there anything else lit up on the dash?
johnwk is offline   Reply With Quote
Old 09-06-2019, 10:48 PM   #6
Paisley777
Drives: 09 Yaris
RESOLVED
Thanks for the feedback everyone
As it turns out, while cleaning up (waiting for the oil to drain) I did indeed jar the SRS connector under the seat. After reading up I connected/disconnected it a few times (yes, neg was removed during that), reconnected and drove - no problem.
Stupid error mixed with somewhat coincidental timing.
Old 09-09-2019, 08:10 AM   #7
Leegamer
Leegamer's Avatar
Glad you figured it out!
Old 09-09-2019, 12:42 PM   #8
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
On Instagram
On Wheelwell
2ZR Turbo Yaris 06YarisRS Forced Induction Forum 562 08-28-2025 02:49 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
TGMO OW20 Oil Change ChilliwackGuy DIY / Maintenance / Service 23 10-24-2010 01:10 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
