Old 09-17-2019, 06:54 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
engine swap
I was thinking bout an engine swap. If you get a salvage engine from a different manufacturer with an ECM... and you can make it fit.. how do you deal with the wire bundles ?? Do you keep any of the original or do you have to run new lights wires by hand?? All the new engine bundles would come with the engine but its how to integrate the lights and fuel pump and AC ,music system etc... how do you approach that??
yaris9876 is offline   Reply With Quote
Old 09-17-2019, 07:22 PM   #2
myfirstyota
3 Yaris and counting..
Body is wired separate from the engine so you wouldn't have to worry about wiring anything body related.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
2003 Yaris 1.3 engine swap help Jedi4690 DIY / Maintenance / Service 0 03-27-2018 03:08 PM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
