Old 09-29-2019, 08:46 PM   #1
groundskeeperwilly
Drives: 2006 Scion xA
Starts the Dies
Hoping someone can help me out here. I bought a 2006 for my son to use as a commuter. It ran fine when we bought it. It needed the usual maint items, so I put it up on jack-stands and replaced a bunch of stuff, including new coils (Denso) and NGK plugs (.032). Now when I go to start it, it fires right up, idles for a second and then dies. It will do this repeatedly but never stays running. I confirmed the fuel pump is running. I went to the local pick-and-pull and replaced every fuse and relay under the hood and dash. Still the same result. Each time it throws all 4 coil codes. I'm baffled. One thought I had....To get it on jack stands, I had to lift one side at a time quite a bit. Does this car have a roll-over switch that might be shutting down the coils?
groundskeeperwilly is offline   Reply With Quote
Engine shutting off at idle, dash lights flickering, and engine starts on it's own! jack.duno DIY / Maintenance / Service 0 09-23-2019 09:08 PM
Sometimes it starts and sometimes it doesn't Roetroc DIY / Maintenance / Service 3 08-15-2019 06:11 AM
2008 yaris starts then dies out in 10-15 seconds Kmartboy808 Hawaii 4 12-24-2018 03:14 AM
Car Dies While Driving josh044 DIY / Maintenance / Service 6 07-28-2017 10:07 PM
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
