Old 10-03-2019, 06:06 AM   #1
mik23
Drives: yaris 2005
Yaris air bag light on off
Hi All
I am not sure what is happened but air bag light is blinking
I had a broken underseat cable which i connected but light is still showing up.
Any help would b highly appreciated.
I have j2534 cable but on srs airbag it gave error so i am stuck.
Thanks
Sent from my SM-G930F using Tapatalk
mik23 is offline   Reply With Quote
Old 10-10-2019, 06:09 AM   #2
mik23
Drives: yaris 2005
Any one ??
Old 10-10-2019, 09:14 AM   #3
Brighton
Knower of little
Drives: None
I have no idea, I'd see if you can find a dealer/mechanic with the specific diagnostic machine to tell you what the problem is.
Brighton is offline   Reply With Quote
Old 10-10-2019, 06:40 PM   #4
B.B._07
Drives: 07 5dr
If you have a broken yellow SRS cable to one of the front seats then that's the problem. If you get it fixed then you can just disconnect the battery and the light will go off. With an ABS/SRS enabled scan tool you can read the ABS or SRS codes, a generic simple OBDII tool will only read check engine codes.
Old 10-15-2019, 03:18 PM   #5
Kazimodo
Kazimodo's Avatar
Drives: Yaris 2007 3 doors
that air bag warning goes on and off for me too , many times in 1 minute ,
at night the headlights go brighter when the air bag light comes on ,
if the wipers are ON , they go faster when the air bag light comes on ,
still looking for possible cause .
just had 5 recalls done to the little car including the spiral cable that was said to
make the air bag go On , did not change a thing ...
Kazimodo is offline   Reply With Quote
Old 10-16-2019, 01:56 AM   #6
toyotavios_11
Drives: Toyota Vios
most probably your alternator/generator is weak
toyotavios_11 is offline   Reply With Quote
Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR toystory DIY / Maintenance / Service 43 04-17-2021 04:54 AM
Yaris crash, air bag did not deploy IllusionX DIY / Maintenance / Service 46 12-23-2014 05:07 PM
