Old 10-03-2019, 10:21 AM   #1
Bikerboy89
Drives: 2015 Yaris Liftback LE auto
Is the DIY unlink AC defrost the same process for the 3rd gen?
Hello I really do not like how the AC comes on when I turn on defrost. I simply want heat to blow. I don't want AC blowing and making the car sluggish for no reason. Is it the same process to unlink the 2 just by breaking off the metal tab as shown in this thread? http://www.yarisworld.com/forums/showthread.php?t=10888
Bikerboy89 is offline   Reply With Quote
Old 10-03-2019, 06:15 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I haven't really noticed the AC making the Yaris sluggish while defrosting.
The AUDM version here does not automatically turn the AC on whe switching to defrost. However, I notice that turning on the AC while on defrost helps clear the siee windows and the rear view mirror.
The AC is basically only being used to dehumidify the air when defrosting, helping tomclesr the windscren faster.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 10-04-2019, 12:05 AM   #3
Bikerboy89
Thanks for the response! The North American version (left hand drive) must have this "feature" do you know where I can find the AC wiring diagram service manual? In another thread it shows you can cut the bright green wire to disable the link but I really don't want to have to buy the manual just for this question.
Old 10-04-2019, 10:28 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I have a copy of the service manual on my Google Drive. You should be able to grab it here: https://drive.google.com/open?id=1-f...tMOb0QO-N6rw1-
You will need to download the file, unzip it and then use a web browser to explore it.
The wiring diageam shows the green wire goes from the AC push button swigch to the AC control module. I suspect there is a link from this switch to a second switch that will operate when the mode dial is turned to the Defrost position. This would be the link to cut, not the one from the On/Off switch.
Old 10-05-2019, 11:56 AM   #5
Bikerboy89
Thanks for the manual!! I actually was told to cut the mint green wire that is on the air direction knob (far left knob by driver) in pin #1 (green/baby blue wire), this wire appears to be the only link to the AC knob.
This did the trick, the AC doesn't automatically kick on anymore when I turn it to any of the defrost positions. If I ever need AC in those positions, I can manually turn it on myself!! Got it all back together.
Old 10-05-2019, 05:56 PM   #6
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Glad you got it sorted out.
DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) CTScott DIY / Maintenance / Service 12 01-22-2022 03:09 AM
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
3rd Gen Sport Pedals ? NYC-SE Cosmetic Modifications (Exterior/Interior) 14 11-10-2018 08:46 PM
2nd vs 3rd gen ride quality + durability chocolab Third Gen Yaris General Discussion 23 11-17-2014 07:30 PM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
