Old 10-27-2019, 02:52 PM   #1
Lays
Drives: 2015 yaris L
Looking for help on ~300 horse build
Hi everyone, I'm building a '15 Yaris for autocross, track, and hill climbs. I was wondering if anyone could look over my plans so far and help me plan my build.
I'd like to shoot for 250-300 wheel horsepower, I have about 7000$ to spend as soon as my second motorcycle sells. I can always spend more later down the road if need be.
The factory ecu is still locked correct? I found a thread saying some guy got his unlocked by some tuning company in Washington. He posted the email and I sent them an email but never got an answer. I also tried googling the name of the company and couldn't find any evidence they even existed.
So I have been looking into standalone, haltech 1500 seems to be go to?
Here's what I have so far on the build list:
Garret 2860 turbo
T25/28 log manifold
Golden eagle intake manifold
Haltech elite 1500 ecu
Walbro 255 fuel pump
Cp Carillo forged pistons 9:1 compression
Brian Crower forged rods
Jun cams, or getting stock ones reground
Bc racing DS series coilovers 7k front 9k rear
Konig hypergram 15x7.5 +35
I don't have an intercooler in mind yet, but I'm fairly sure the big gap between the front bumper cover and radiator should allow me to get some sort of decent sized universal one.
As for throttle body, and injectors I'm not sure either.
I know I'm still missing quite a bit, which is why I wanted to ask for advice.
I've already spoke to a tuner that recommended I get a haltech and around the same size turbo I've mentioned.
Thanks guys!
Lays is offline   Reply With Quote
Old 10-27-2019, 07:41 PM   #2
I'm not necessarily the guy to speak to regarding turbo builds but from listening to many other people who have a lot of experience in this area in regards to trying to build a turbo motor on an original NA motor and make it reliable at your whp range, you will need to raise your budget a few grand.
The best advice I was ever given was "fast, cheap, reliable - pick two"
I'm not saying 7 grand is a "cheap" amount by any means, but to properly manage heat and maintain those power numbers I would expect it to cost an easy 10 grand.
It's one thing to build a street cruiser but a serious track rat that can do more than 10 min sessions will start to show all the weaknesses.
Just my $0.02
Old 10-28-2019, 03:12 AM   #3
Lays
Just my $0.02
7 grand wasn't my total budget, it's just what I have to start out with. As I get future paychecks etc I can dump more in.
Old 10-28-2019, 08:31 AM   #4
myfirstyota
3 Yaris and counting..
I'll bet 06YarisRS has over 10 grand in his setup and he's only running 7psi boost. Mind you he is 2zr swapped. But probably still 100hp short of your goals.
If you do end up building a 300hp setup, I'll be following
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 10-28-2019, 07:53 PM   #5
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Haha, some day I'll figure out the total cost, but, yeah, it's up there. The 2ZR swap was about $2500.00 USD with all the extras (hardware, engine mount, ecu, harness etc) and the turbo kit, probably about $3500.00 USD, including lots of little extras such as intercooler couplers, hardware, exhaust work, trans cooler with themostatically controlled fan, gauges etc. I made some mistakes and lack of pre-planning (aka, doing the swap before I decided to turbo the car) which cost me money to redo things.
I really hope this build goes forward. I'll definitely be following it too if it does. I'm always looking at lower compression pistons, head gasket, head bolts and rods (Molnar or MWR most recently due to their lower price as opposed to Crower) in the event that I ever decide to build my engine. I've also looked at the Haltech 1500, but the ECUMaster Black looks like a cheaper, and possibly as good, alternative.
Oh, and with regard to hacking the ECU, here is a response I got from ftgtuning (ftgtuning@gmail.com):
#1 send me a picture of the ECU tag anf connector you are running so we can see if we have done anything with that variant before.
#2 are you using the factory pressure sensor?
Depending on the ECU and programming language the only way to force open loop would be with throttle control at a certain percentage (besides WOT) but without spending time working on it we cannot say for sure yet. We have done some other makes to 10-15% throttle to drop into open loop and that works well.
Just to give you a heads up if we can do what you want it is going to be ~$350 for the work and we would need your ECU sent to us to do it. Before we get to that though send a picture and we can figure out what we can and cannot do for you.
Old 10-29-2019, 09:20 AM   #6
Great info on the ECU hack. $350 is somewhat reasonable and I will he looking into this for next season
Old 10-29-2019, 07:26 PM   #7
06YarisRS
Yeah, I'm seriously considering having them do something with my ecu. First, however, I have to find out all the potential pitfalls of forcing the car into open loop at lower throttle positions. Of course, a completely new fuel map would be needed. That could be tricky. It might be worth the investment to buy on eBay a used ECU and have it delivered directly to them and ask them to list everything that they could do with it. I only paid ~$18.00 for my ecu with free shipping, so that's squat. I wonder what they'd charge to crack into one and see what the capabilities are. Frankly, if I could do away with the F/IC, I would. Maybe our ECUs could be configured to handle low boost, such as mine, without the need for any additional computer. You're running an xD ECU, but for manual, correct?
Old 10-31-2019, 06:10 AM   #8
Yup, I have a manual ecu installed. Having them tune an extra ecu would he a bonus so you could always go back to your current set up if needed.
I'll have to contact them down the road to get a price from them. I'm looking to increase the redline to 7500 rpm and have timing advanced for 93 octane.
Old 10-31-2019, 10:19 AM   #9
06YarisRS
Nice. I'm guessing you have 93 readily available. Or would you be mixing your own 'track' gas?
I've been reading a bit lately about the 2ZRs having issues with the head gasket between adjacent cylinders. Also, been trying to find out more about head gaskets and head bolts. Everything I've read about the 2ZR suggests that it can handle forced induction at low boost. Although not boosted you've run yours through the ringer and had no issues there, right?
Old 10-31-2019, 11:07 AM   #10
Lays
Well nevermind, this morning I totalled my car coming home from work.
I still have some 60 treadwear advans on my car from the last autocross event a few weeks ago, I was planning on putting my normal tires on next week because it's been like low 30 degrees outside.
Rear end came out when I was coming around a corner this morning around midnight, it was 29-31 degrees, I tried to counter steer and save it but no luck.
I went through a telephone pole, a huge fence, and smacked into a giant tree.
Old 10-31-2019, 02:37 PM   #11
Hole crap dude, I hope you are ok! That a tough loss, hope you recover alright
Old 10-31-2019, 02:39 PM   #12
Some local Esso stations sell 93 and PetroCan have 94. They are not that close to me but convenient enough to go fill up some cans for track days
Old 10-31-2019, 03:49 PM   #13
Leegamer
Leegamer's Avatar
Jesus, glad you're ok!
I'm a hermit named Lee
Old 10-31-2019, 06:02 PM   #14
06YarisRS
Yes. Glad you're ok. That looks like quite a fender bender.
Old 10-31-2019, 06:06 PM   #15
06YarisRS
I'd love to have access to 94. Fortunately at least I have access to 93 within about a half hour drive. I have to go close to that location once a week anyway. The other thing I've been trying to find out - with no success - is just how much more detonation resistant 93 is as opposed to 91.
Old 11-01-2019, 09:18 AM   #16
myfirstyota
Happy to see you're still alive!!!
Old 11-01-2019, 03:06 PM   #17
Lays
Here's the rest 😔
Old 11-01-2019, 08:47 PM   #18
06YarisRS
Again, glad you were unscathed by what looks to be like quite a serious accident. As for the car...
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
Tesco Horse Meat Scandal *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 02-20-2013 09:48 PM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
