Old 10-29-2019, 03:41 PM   #1
sv650steve
Drives: accord (for now)
Won't start/ broke down
I had a cracked fuel line where they have a habitual problem and I had it rigged up until I got the part but I might have pinched it. I have spark. Car won't crank. Fuel comes out when fuel line is disconnected. I heard a strange noise I can't describe and lost all power and won't crank up. It sounds sometimes like it's trying to fire, and turns over. Where do I go from here?
sv650steve is offline   Reply With Quote
Old 10-29-2019, 03:42 PM   #2
zoidberg444
zoidberg444's Avatar
Will it go on starting fluid or brake clean?
Sent from my SM-G965F using Tapatalk
UK to Nordkapp in a Yaris
Old 10-29-2019, 03:48 PM   #3
sv650steve
I'll have to get some and see
Old 10-29-2019, 04:14 PM   #4
sv650steve
no change with starter fluid sprayed onto cai filter
Old 10-29-2019, 07:34 PM   #5
zoidberg444
I guess the next easiest test to do is to check for spark. You can get a spark tester and there is plenty online to show you how to use one.
In order to run engines require:
Fuel
Air
Spark
Timing - Crank & Cam
Exhaust
Compression
The fact it wouldn't go on starting fluid indicates its most likely not a fuel issue. Starter fluid is like crack cocaine for engines. Even a shitty one should go on it. The fact that it cranks rules out something like park/neutral or clutch switch. If you have spark my next suspicion would be some kind of internal issue with the engine. Which is probably beyond the average person to diagnose.
Old 10-30-2019, 07:12 AM   #6
ex-x-fire
I'd remove all the spark plugs and turn the engine over by hand. Does it get tight?
Old 10-30-2019, 09:54 AM   #7
sv650steve
Good call on move it by hand. I've already tested spark on one coil with a screwdriver and it has spark....Things are starting to look bad.
Old 10-30-2019, 10:22 AM   #8
sv650steve
#2 cylinder threw a rod. Spark plug looks like it's been smashed with a hammer, and the piston is way further down than the matching one.
Old 10-30-2019, 05:17 PM   #9
zoidberg444
Yikes. Sorry to here that mate. Was it a 1.5 or 1.3 engine? How many miles?
You might be able to get a used engine from the scrapyard.
To start or not to start? Doix DIY / Maintenance / Service 11 12-10-2023 08:30 PM
The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. YarisVVTi2002 DIY / Maintenance / Service 2 09-16-2019 05:43 PM
Remote Start Bug, please help jeeper5usa In Car Entertainment + Electronics (audio / video / alarm) 5 01-02-2014 08:36 PM
My car doesn't start yaristhebest General Yaris / Vitz Discussion 11 01-10-2013 10:02 PM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
