Old 11-30-2019, 12:48 AM   #1
remcafee
1zz throttle body swap rev hang
i recently did the 1zz throttle body swap and i did do the chip swap and i looped the coolant lines at the block to bypass it, anyone know how to get rid of the annoying rev hang that happens for like 3 seconds straight when you let go of the gas, its like its still goving it throttle even though you are not. 🥺
Old 12-08-2019, 11:31 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I don't recall anyone having an issue with that before, but I may have missed it. Have you checked to make sure that the valve returns by itself and closes correctly? If it was used, it's possible that it's dirty/fouled and getting stuck.
Old 12-08-2019, 06:08 PM   #3
remcafee
it is a used unit, i have cleaned it out with throttle body cleaner, you think it might be the way the airflow transitions into the maifold opening? it doesnt have a smooth flow going into manufold it just steps down you know what i mean? i also only tried it for about a mile or two, thrn i went to original, you think i would need to drive around more possibly?
Old 12-18-2019, 07:27 PM   #4
remcafee
Originally Posted by alec801 View Post
I also had this issue when I was using 1zz throttle body. I don't have any fix for it but I can confirm it is a common issue with this mod
yeah man its weird how long have you tried driving around with it? i wonder if it needs more time
Nitto midpipe, throttle body swap MatthewMenze Willing to Buy by private party 2 05-27-2017 01:31 AM
FS: 1zz corolla intake with tooter flange and 1zz throttle body instantninja Items for Sale by private party 13 04-28-2017 09:41 AM
JB Weld stock intake manifold port w/ 1ZZ Throttle Body tmontague Performance Modifications 2 10-07-2015 09:31 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
