Old 12-04-2019, 04:15 PM   #1
pointyskull
Drives: 2014 Toyota Yaris 4 DR HB
2014 Yaris 4 door factory radio replacement question
We just bought a 2014 Yaris 4-door, and it had the factory radio (see attached image).
I am not terribly pleased with the audio quality, and have been looking at aftermarket units. My dumb guy question is if I put in a replacement how much of an improvement can I expect in sound quality?
I've been looking at units in the 200$+ range, but I'm not sure if I would need to have the speakers replaced, too.
Thanks for any info/recommendations.....
pointyskull is offline   Reply With Quote
Old 12-04-2019, 09:12 PM   #2
myfirstyota
3 Yaris and counting..
Normally not much
But if you replace with a unit with high adjustability features (multi band eq, internal crossovers, and other adjustability features) you'd be surprised.
I have a kenwood excelon kdc-x990 and although very outdated, I was able to get better sound out of the stock speakers without using an amp... not that you would want to use an amp with the stock speakers anyway. I dont imagine they'd last very long if you did
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 12-06-2019, 12:50 PM   #3
Niki Knuckles
Drives: RS
You can keep the factory head unit and still get a more powerful sound.
This is the way...
https://youtu.be/MJ2EO4Ma6p0
Clarion had an amplifier that has everything built in, just hook it up.
https://www.google.com/search?q=clar...w=1280&bih=623
Finally, change the speakers when you can. You will need them to handle the power from the amplifier,
and add a Subwoofer!
Niki Knuckles is offline   Reply With Quote
Selling my Yaris - Clutch Replacement Question Swoleslaw DIY / Maintenance / Service 9 11-05-2011 12:27 PM
