Old 12-29-2019, 09:05 AM   #1
toyotavios_11
Drives: Toyota Vios
Rear deck ticking noise due to body flex
Owing Yaris sedan 07 model. Recently notice that there is ticking noise from rear deck whenever the car is over rough pavement. Initially thought that it was due to rattling of interior panels, so removed all the rear panels including seats and seatbelt mechanisms to diagnose the source of noise, but ticking is still there. Hide to the trunk to check the noise when someone is driving for me and notice that the rear seat striker panels which welded to the rear deck are making the noise due to body flex.
I try to "crack" the five spot weld points of each striker panel but useless and now im clueless to solve this.
toyotavios_11 is offline   Reply With Quote
Old 12-30-2019, 09:15 AM   #2
nortonfb
Drives: 2007
If the seam is open you can try foam insulation (expanding) or caulk.
nortonfb is offline   Reply With Quote
Old 01-02-2020, 12:06 AM   #3
zoidberg444
zoidberg444's Avatar
The Yaris is a pretty noisy car. You could try butile insulation like dynamat. It's this heavy tar like stuff that absorbs a lot of the vibrations and resonance that thin sheet metal in cars creates.
UK to Nordkapp in a Yaris
Old 01-02-2020, 12:10 AM   #4
myfirstyota
3 Yaris and counting..
Rattles and reliability. Yaris definitions.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 01-02-2020, 06:59 AM   #5
ex-x-fire
The yaris is quiet compared to a focus.
Old 01-02-2020, 09:47 AM   #6
myfirstyota
I'll take your word for it. I have no inentions of owning a ford anytime soon ha!
Rear window sedan crackling noise. krolos General Yaris / Vitz Discussion 3 04-09-2011 12:39 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Noise coming from rear end! tfman716 General Yaris / Vitz Discussion 15 10-28-2008 12:37 PM
