Old 12-30-2019, 06:55 AM   #1
CrimsonEclipse
Drives: .
TPMS Problems. Possible to Disable?
I have a 2011 Yaris that has a TPMS problem.
It intermittently flashes for 1 minute then stays illuminated.
I already know that this means a TPS fault.
I am considering disabling or bypassing the system or even just removing the associated light bulb or LED.
I also am familiar with the rather large thread on the GEN2 Yaris TPMS bypass, but that one doesn't apply to a GEN3 Yaris.
So the questions are:
Can I disable or bypass the TPMS system on a GEN3 Yaris?
Does a TPMS fault show up on an OBD2 check for a State Inspection?
CrimsonEclipse is offline   Reply With Quote
Old 12-30-2019, 01:51 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
2011 Yaris is a gen 2 car.
Old 12-31-2019, 02:34 PM   #3
bentjazz
Drives: 2009 Yaris--3dr MT
Just had this same thing arise with my 2010 Yaris. Dealership wanted $230+ to replace EACH sensor. I've had my car 9 years, and the functional life of these sensors is 7-10 years, so I wanted to swap out all the sensors, because I can see them all going bad sometime very soon. Well, to swap them all out would be around $950. Don't think so. I took it to Costco, and they swapped out all 4 sensors, balanced my tires, and filled them with nitrogen for around $240. I know this doesn't address your question, but I thought I'd share my experience concerning my TPMS situation. Good luck.
Old 01-04-2020, 05:20 AM   #4
CrimsonEclipse
Drives: .
Thanks guys.
Yeah, it IS a 2nd gen. So... there's that.
I'll get to the proper sub forum.
cheers!
TPMS warning light flashes then stays on Hamster DIY / Maintenance / Service 9 11-12-2019 08:49 PM
HAve To Use Spare: How to disable TPMS light? bronsin DIY / Maintenance / Service 6 01-09-2014 06:20 AM
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
