Old 01-22-2020, 12:13 AM   #1
Rob888
Drives: 2010 Yaris 2 door hatchback
Need front wheel alignment specs
I made a camber tool that consists of two bolts attached to a metal bar to which is attached a digital level gauge.
These are the angle measurements I got on all four wheels on my 2010 Yaris two door hatchback:
front driver side=88.25 degrees, front passenger side=87.39, rear driver side=89.17, rear passenger side=86.82. So, for example, the front driver side camber would be:90 degrees-88.25=1.75 positive camber I believe. The tool displays zero degrees when laid on a flat surface.
What are the factory camber specification degree ranges for the front and rear wheels?
I adjusted the toe alignment on this car using a string method. I set the front wheels toed out 1/16" on each wheel for a total 1/8" toe out. One sixteenth toe out per wheel is typically recommended for front wheel drive vehicles. What is the factory toe specification range in inches for a 2010 Yaris two door hatchback?
I found this table of alignment specs for my Yaris, but I'm not sure how to read it. https://www.autozone.com/repairguide...96b43f81b3d92d
Does the table say that the camber spec range for the front wheels is -.34 to -.50 degrees and for the rear wheels is .04 to .20 degrees? The toe spec range for the front wheels is listed as 13.07 +/-.75. Does that toe range mean 13.07 degrees +/- .75 degrees in relation to a straight line parallel to the car and through a perfectly straight front wheel? What is the spec toe range in inches? Thanks for any replies.
Rob888 is offline   Reply With Quote
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 03:36 PM
Alignment Specs Question xnamerxx Tracking, Racing, Auto-X Forum 20 06-26-2012 12:14 PM
Front Passangerside wheel bearing yaris4062007 DIY / Maintenance / Service 5 03-09-2012 01:34 PM
wheel alignment after wider rim/tire install? 2manywheels Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 08-25-2010 05:12 PM
Damaged Front Bumper PLEASE READ!!! Wheel Cover?! christolphe Cosmetic Modifications (Exterior/Interior) 8 04-22-2010 11:52 PM
