Old 02-15-2020, 11:16 AM   #1
Neinris
2008 Hatchback Rear toe in/out question...
Aloha everyone! I have a 2008 hatchback which I’ve lowered with Tein’s lowering springs. Lowering obviously caused the wheels to camber, more significant in the rear than the front. I see that the rear tires have some significant wear on the inside, and it’s been almost 3000 miles since I lowered her. I was thinking though that the rear are only slave tires, doesn’t do much work compare to the front ones, and shouldn’t wear as much. So I was wondering if lowering also caused the rear to toe in or out which is contributing to the wear. What do you guys think?
2008 toyota yaris 2 door hatchback water leak knobby bobby DIY / Maintenance / Service 8 07-03-2024 06:42 AM
Solved: Clunk in Rear Suspension (2008 Yaris 3-door) Redbat01 DIY / Maintenance / Service 2 02-10-2015 12:33 PM
Echo HatchBack 15X6.5" 42ET Nitto NeoGen 205/50R15 . Rear Spacer or not ! mpcv2000 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-10-2014 10:32 PM
this may be a old question but i am looking to change my rear view mirior 2 power 1 pennyracer In Car Entertainment + Electronics (audio / video / alarm) 2 11-29-2013 09:28 AM
