Old 03-14-2020, 01:33 PM   #1
la_scanner
Drives: 2007 toyota yaris
P0302 cylinder 2 misfire
2007 Toyota Yaris:
Check engine light came on, P0302 came up on the computer which indicates a cylinder 2 misfire. Vehicle taken to the mechanic and he wants to put in a new coil and replace the four spark plugs. I did not have the work done because the mechanic stated that the four spark plugs are past their time.
The car has 134,000 miles. In 2017 at 107,000 miles, all four plugs were replaced by Toyota. As we all know, these should go about 100,000 miles.
Should I just go with what the mechanic is saying, whether he does it or someone else? Personally I feel like there is some other underlying issue. In 2009. diesel fuel was put into the car. The cat was replaced and so were the spark plugs. So, in this cars lifetime, it has had the original plugs and replaced twice and now ready for a third time. The battery in the car has been replaced either four or five times. Has had a new fuel injector, alternator replaced. Also, throttle plate cleaning. Are these list of things related to the coils and/or plugs?
Oh, and does anyone have toilet paper?
Thanks!
la_scanner is offline   Reply With Quote
coil, maf, p0302, spark plugs
Misfire cylinder 3-4 yaris 2007 vandammages DIY / Maintenance / Service 0 05-09-2017 08:57 PM
Cylinder 1 misfire and catalytic converter issue Lu Xun DIY / Maintenance / Service 3 08-24-2013 06:37 AM
Misfire into multiple cylinder! maxthehax Forced Induction Forum 21 12-12-2012 12:18 PM
P0300 Random / Multiple Cylinder Misfire DetectedCylinder 3 misfire dante2086 DIY / Maintenance / Service 4 05-15-2011 04:36 PM
