Old 04-15-2020, 11:11 AM   #1
Pinchlite
Drives: 2007 yaris HB
Manifold to exhaust pipe bolts...
I have 2 choices for these bolts.The gold colored ones dont seem proper for some reason?
Both say they are for 2007 hatchback.
https://i.imgur.com/qMw1Ik7.png
https://i.imgur.com/J1L4mX3.png
Pinchlite is offline   Reply With Quote
Old 04-15-2020, 11:49 AM   #2
Brighton
Knower of little
Drives: None
Neither of those look like the ones I used on my 07 hatch... BUT walker is a trusted brand imo
Brighton is offline   Reply With Quote
Old 04-15-2020, 11:51 AM   #3
Pinchlite
Another thing I notice is no nuts.I suppose one of the flanges are threaded?
Old 04-15-2020, 02:59 PM   #4
either one is likely fine. its just the companies way of getting to the same end result.
the flange on the manifold IS THREADED so there is no need for a bolt for the backside...(front side?)
Old 04-15-2020, 03:04 PM   #5
Pinchlite
Alright thanks.I will probaly go with the black ones as I dont see how the gold ones would fit through holes in manifold and pipe with those round things on top of threads.
Old 04-15-2020, 06:09 PM   #6
iirc the holes in the midpipe are bigger than the holes at the manifold.
Old 04-15-2020, 06:13 PM   #7
Pinchlite
These round things is what I am referring to.Are they small enough to go through openings,or are they just movable washers?
https://i.imgur.com/DO93WCZ.png
Old 04-15-2020, 06:47 PM   #8
ex-x-fire
The top ones are made better (like an OEM part), the bottom ones are just a bolt, spacer, washer, and spring. It does the same thing but with added components to hold the spring and limit over tightening it.
Old 04-15-2020, 06:48 PM   #9
Pinchlite
So that thing I pointed out is a limiter.
Good to know thanks.
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
Exhaust pipe gasket umm_bacon DIY / Maintenance / Service 1 09-23-2007 07:30 PM
