Old 06-06-2007, 08:55 PM   #1
Lillydot
Absolutely Red!!!
Lillydot's Avatar
Drives: 07 A/T Yaris Liftback
I give up!
alright. i'm tired of trying to get my miles to go up. i've been driving like my grandma for the past 4 months! its sucking the life out of me! i'd rather get 25 miles per gallon, but drive the way i like! i'm a little bit above 3,000 miles, and i'm about to get an oil change. someone told me that might help. i don't know...
Lillydot is offline   Reply With Quote
Old 06-06-2007, 08:58 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
why change at 3000?
SPONSORED BY
Old 06-06-2007, 09:00 PM   #3
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
do it if you got the dough!
don't give up!!!! i believe in u!!!
-- Blen
Old 06-06-2007, 09:08 PM   #4
what are you averaging? i'm averaging 39 mpg.
do you do "jack rabbit" starts? i feather the gas pedal from a stop and i don't go below 1500 rpm. i shift at 2500 rpm from first to second, and shift 150 rpms lower after that. and i drive mostly on the freeway.
Old 06-06-2007, 09:14 PM   #5
brickhardmeat
Lonesome Cowboy
i floor mine to the next red light and slam on the brakes
SPONSORED BY
Old 06-06-2007, 09:17 PM   #6
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
+1
I have always had an increase after engine break in. The only thing is all my other Yotas have been real tight (engine wise) and seemed to be really hitting there stride at about 30K.
blacksan is offline   Reply With Quote
Old 06-06-2007, 09:37 PM   #7
Vervepipes
CowCountry Hornet Handler
Vervepipes's Avatar
Drives: '08 Sedan
check to make sure none of your wheels are seized or the park break accidently on?.... if Auto that it's in OD instead of 3?...
Vervepipes is offline   Reply With Quote
Old 06-06-2007, 10:03 PM   #8
brickhardmeat
Lonesome Cowboy
ha,ha drove it off the lot with the parking brake on and for the last 4 months, that sucks
SPONSORED BY
Old 06-06-2007, 10:04 PM   #9
Lillydot
Absolutely Red!!!
Lillydot's Avatar
i'm averaging 28 miles per gallon. i do all city driving, mostly stop and start as i drive mostly during rush hour to and from work. a guy at the hyundai dealership (my botfriend just got a new car) said to change after the first 3,000 and then every 5,000 after that to help break the engine in. i haven't been doing jack rabbit starts, but i damn sure am going back to that now. i am soooo fed up with everyone darting in front of me cause i'm going so slow!
Old 06-06-2007, 10:16 PM   #10
Blenjar
Blenjar's Avatar
HAHAH ME 2!!
-- Blen
Old 06-06-2007, 10:32 PM   #11
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
1) check your tire pressure - i run at 40psi for a comprimise between ride/handling/mpg
2) change your oil every 5k. toyota has put hundreds of thousands of dollars into research, and they say 5k. the us military has put hundreds of thousands of dollars into reasearch, and they say 10k ... everyone else either works for the oil industry (and wants you to buy more oil) or is guessing...
3) in dusty conditions, change your air filter...
4) http://www.yarisworld.com/forums/showthread.php?t=5979
that link has more info than you'll ever want to read...good ideas though.
fu_im_from_texas is offline   Reply With Quote
Old 06-06-2007, 11:01 PM   #12
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
why change at 3000?
the dealer told me to change every 3000. something to do about the heat in texas and how it effects the oil as it sits in your car.
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 06-06-2007, 11:37 PM   #13
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
did you calculate it right? my is sedan and i can do average of 34 to 35.
Don't drive slow it's not help at all
i do drive like a gramma b4, shift at 2500 or less and still not help,
but now i drive fast and hard most of the time, AC on all the time, shift at 3000 to 4000, carrying at least 30-50 pounds of junk all the time, and average is about 34-35mpg. i do change my oil every 3k.
Old 06-06-2007, 11:45 PM   #14
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
this is the absolute worst kind of driving when trying to achieve good mileage, i would say 28 mpg is not terrible for city driving, especially if it is bumper to bumper rush hour traffic.
my car is used mostly around town and i average about 29 mpg in the winter but now it is up to 35 mpg since the weather warmed up.
your mileage will also improve as the engine breaks in more.
jack rabbit stars won't get you anywhere more quickly, they might be fun but they aren't going to achieve anything.
stuffy is offline   Reply With Quote
Old 06-06-2007, 11:46 PM   #15
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Don't worry! I averaged 32-35 the 1st 4,000, since then 37-42 and have 9,300 miles now. Yes I changed my driving a bit, but not that much....42 psi in the tires,more used to the car, and I think it finally broke in, and may still be improving.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 06-06-2007, 11:54 PM   #16
uncleyaris
calm down, the oil in the engine helps break it in. wait for the recommended oil change. drive wisely, and it will change. The engines already have some break in. remember you are getting better mpg than most, and you have to find your groove!!
Old 06-07-2007, 12:05 AM   #17
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
I drive my car like I stole it, every where I go I give it hell, I usually shift out of 2nd at 20 then to 3rd at 40-45, then into 4th at 60 and into 5th when I feel like it. I still average 32 miles to a gallon and this is all with 18 in wheels!
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 06-07-2007, 12:32 AM   #18
Vervepipes
Vervepipes's Avatar
Drives: '08 Sedan
yeah, if it's stop and go traffic dont forget that every minute you're sitting idleing your still using fuel, unless you do like me and shut the engine off if you're not moving for a while!
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 05:41 AM
Next Project is >>> To give my Yaris, Wings ! Yarisagos Cosmetic Modifications (Exterior/Interior) 50 05-17-2007 07:47 PM
Joined the Army Dragonacc Off-topic / Other Cars / Everything else Discussions 27 05-15-2007 02:47 AM
ITT: We give give Re-birth to Future Mods vodkalush General Yaris / Vitz Discussion 23 04-22-2007 08:58 PM
Get your Yaris without waiting! costaricandreams New YARIS Purchase Forum 52 07-22-2006 10:42 AM
