Old 04-16-2020, 05:57 PM   #1
gubloom
Drives: Silver yaris
Which Side Tire Wears Faster
I own a 2016 model Yaris 1.5 manual hatch. 65000 miles.
I previously had 205 50 16 tires and now I have 195 50 16.
I noticed that the passenger side front tire wears much faster than the drivers side tire ? I believe this is a fact. Does not make sense but its true.
My question is which back tire wears faster passenger side back or drivers side back ? Any comments ?
gubloom is offline   Reply With Quote
Old 04-16-2020, 06:16 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I have a 2014 with 195 50 16 tires. I have never noticed a difference in tire wear concerning which side of the car they were mounted on. The fronts will wear faster than the rears, but side to side should be the same.
Old 04-16-2020, 07:03 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
For my 2007 and 2014, I've had more sets of tyres than I can remember. Like NYC-SE, I never noticed any difference in wear from left to right.
Old 04-16-2020, 07:14 PM   #4
gubloom
I can tell you for sure that the passenger front tire wears quicker. I understand that this may not make sense but its true. Observe your tires every 3 moths you will tell the difference. Its the back I am not sure about.
Old 04-16-2020, 09:01 PM   #5
I've had 2 Yarii, and countless sets of wheels and tires between the two (mainly all on my first one). Both sides should wear at the same rate. If not, then you have an alignment problem. And if your alignment is good, then you're taking right turns too fast. Do on/off ramps mainly go to the right down there in Australia?
Old 04-16-2020, 09:37 PM   #6
gubloom
read this guys I am right
https://www.toyotires.com.au/news-an...re-wear-faster
Old 04-16-2020, 09:41 PM   #7
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Lots of different experiences here. I'll weigh in too. I have noticed more tire wear on my passenger side front tire. However, this has only become noticeable since engine swapping and turboing. The left tire is the one that breaks loose most often under boost. I don't have a lot of extra wear, just a bit, but noticeable. I try not to spin, but it does happen occasionally. As far as I know, my alignment is spot on. Tire wear is completely uniform. I'll get my tire depth gauge out and measure the difference between right and left front tires. No difference whatsoever in rear tire wear.
Old 04-16-2020, 09:50 PM   #8
NYC-SE
NYC-SE's Avatar
The physical characteristics of the roads described in that article are true. Theoretically I could see how it could make a slight difference in tire wear, however in actual real world situations I have never seen a difference in side to side tire wear on any car I have owned. Of course I always rotate my tires every 5000 miles (give or take). I suppose if I never rotated tires and ran them to the end of their life in their original positions perhaps this phenomenon would present itself, but why would one do that?
Old 04-16-2020, 10:17 PM   #9
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Hi to another Sydney yaris owner!
I bought the Yaris as a second car last time we swapped vehicles. I have only done 45000 km since I last bought tyres, and they are rotated at each service. I haven't noticed any uneven wear.
However, my previous car (mostly driven by my wife) definitely wore the front passenger tyre faster. I think this may be because she tends to take roundabouts at a much higher speed that I do. YMMV.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 04-16-2020, 10:31 PM   #10
gubloom
I do about 30000 km per year mainly around the city of Sydney. Lots of stop starts and lots of roundabouts(circles). I believe this is the main reason I can easily see the wear difference between the right tire and left tire, My Yaris is also manual 1.5 L engine. I dont rotate my tires as the back two are a different brand and make.
Can anyone comment on which rear side will wear quicker ?
Old 04-17-2020, 09:06 AM   #11
06YarisRS
Not Yaris related, but I just had my 2013 VW Golf Sportwagen in for an alignment yesterday. First, I must say that the dealership had a very good policy regarding contact. They used a key drop box with hand sanitizer etc. I was experiencing some sawtooth wear on one rear tire inner shoulder. The toe was off from spec. They made the necessary adjustment, back to spec. Camber at all 4 wheels was good with one wheel slightly out of spec. No other tires on the car showed abnormal wear prior to the alignment.
I'm not sure if the Yaris has any adjustability at the rear. Overall, I've never had any abnormal tire wear on any tires of either Yaris I've owned. Well, other than the passenger side front tire on my 2006, but I wouldn't call that 'abnormal' wear.
Old 04-17-2020, 04:23 PM   #12
I would expect your rear passenger side to wear quicker then since your front one is (due to the roundabouts you mentioned). However, since you said the rear two tires are different from each other, it's possible that the one that is has a better traction rating (should equate to more grip) will wear faster since those tires generally don't last as long as tires with less grip.
Old 04-17-2020, 04:24 PM   #13
The Yaris does not have any factory adjustability in the rear. I believe you have to use shims to adjust alignment.
Old 04-17-2020, 06:06 PM   #14
06YarisRS
Yeah, I didn't think so. Thanks.
Old 04-25-2020, 10:23 PM   #15
SECProto
Drives: 2012 Yaris LE
Maybe you're right for yourself, but my tires wear at identical rates.
I rotate them every 5 to 7 months (as I use winters for 5ish months of the year, all seasons for the other 7, and rotate tires each time I put them on), and I don't corner aggressively.
SECProto is offline   Reply With Quote
Old 04-27-2020, 07:20 AM   #16
amypang
Drives: Toyota Yaris (XP150)
If everything is okay, most probably front tires wear a bit faster than rear tires. Tire rotation is the exact way to even tire wear. But, in your case, you have changed the size of you tire. Perhaps, this changing might be the cause
amypang is offline   Reply With Quote
Old 05-21-2020, 11:22 PM   #17
Suzaku
Drives: 2008 yaris
My 2008 Yaris does the same, 1.5 manual hatch.
right front wears fastest, it has done that since I got the car ( used ) and it's NOT an alignment issue , it was aligned when I got it, and checked once sice I had it in the last 4 years.
when hard acceleration, the RF is always the first to break traction, and hard breaking, it's the first to lock up.
I've come to expect it from the car now
Suzaku is offline   Reply With Quote
Drivers side JDM taillight jdmekcivic Items for Sale by private party 4 07-09-2011 01:57 AM
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 04:54 PM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
