Old 04-19-2020, 11:53 PM   #1
Mathcdu
Drives: Yarris 2007 blue
Unhappy Yarris Wheel Crooked
Hi guys,
I am seeking help for a problem that ive had for a couple of months now.
The left rear wheel of my yaris seems to be a little bit crooked from the inside .
When i went to the garage he told me that the problem was a bent axle.
I believed him so i had it changed.
The problem is still there even after the axle change...
Could it possibly be something with the wheel hub or weak suspension ?
Is it something normal ?
There is no vibrations even at high speed.
My alignment is very bad and needs to be done.
Cheers
Mathcdu is offline   Reply With Quote
crooked, hubcap, wheel, wheel offset, wheels
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 12:19 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Crooked Steering Wheel 07 5 door hatch DDPK DIY / Maintenance / Service 3 06-17-2015 04:38 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
