Old 04-20-2020, 02:41 PM   #1
billfires
Drives: 2010 3dr LB
Parking light short circuit?
My parking lights on my 2010 manual trans 3 door HB are turning on (flashing) when the left turn signal is operated. Also the parking lights come on when the brakes are applied. This happens when the parking lights are in the off position. All the bulbs are working normally. I have not had the opportunity to check the wiring in the driver's side rear light yet. Just wondering if anyone else has run into this problem. Thanks, Bill C
billfires is offline   Reply With Quote
Old 04-22-2020, 07:36 PM   #2
billfires
Drives: 2010 3dr LB
Just a follow up, it was the trailer light converter. Unplugged the left turn signal and brake light wires and everything works as it should. Bill C
Unexpected Seat Belt Light Flashing ern-diz DIY / Maintenance / Service 19 09-23-2018 01:03 AM
Increasing head lights output (full LED setup) David C Cosmetic Modifications (Exterior/Interior) 23 04-29-2018 06:26 PM
Battery Warning Light - Different Twist maybe RutherfordmanX DIY / Maintenance / Service 3 06-08-2015 08:59 PM
Parking Light Flash Output vs Hazard Light Output sex DIY / Maintenance / Service 2 11-03-2009 08:47 PM
Yaris and Echo short shifters sale, $30 off! TWM Performance TWM Performance 8 11-17-2008 02:23 PM
