Old 05-13-2020, 02:01 PM   #1
mr_fixit
Drives: kids car
Lose the hub caps, I want OEM aluminum wheels 2009 SEDAN. What's my choices?
Will all 2007 through 2016 OEM Yaris 15" or 16" aluminum wheels fit my daughter's 2009 YARIS Sedan? First choice would be 15" so we can use the same tires.
I bought my daughter, a new driver, a 2009 Yaris sedan, and she's already lost a couple hubcaps. So I want to find some 15" ( or 16" ) OEM aluminum wheels, that will bolt on , without anything but lug nuts.
The reason for OEM wheels is that I want to be able to find one in the future if/when my daughter, a curb, or our potholes kills a wheel.
I really looked at a bunch of threads, but couldn't find a question like this. Thanks.
And is there any difference between lugs nuts types between 2007 and 2016?
mr_fixit is offline   Reply With Quote
Old 05-13-2020, 02:58 PM   #2
Whatever you can find OEM Yaris will fit. There is no change in bolt pattern or hub bore across model years.
Old 05-14-2020, 09:52 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
You can see what options are available at salvage yards by going to car-part.com. That's where I usually start my search. OEM alloys will be pretty hard to find though, the majority of them shipped with steel wheels and hubcaps. You may be better off going with an inexpensive aftermarket alloy instead--MB makes those generic 5-spoke wheels in almost every conceivable size and bolt pattern and are reasonably priced (around $100?). You can look for more stylish options at Tire Rack if the national tire shop chains don't have anything that strikes your fancy.
Old 05-14-2020, 09:59 AM   #4
Leegamer
Leegamer's Avatar
Any 4x100 wheel with an offset in the high 30s to mid 40s should work like OEM
I'm a hermit named Lee
Old 05-14-2020, 01:06 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
OEM Hyundai Accent wheels have the same bolt pattern and centre bore as well.
Old 05-14-2020, 01:22 PM   #6
Around 2007/08 and newer I believe. Prior to that, the bolt pattern was 4x114.3
Old 05-14-2020, 11:12 PM   #7
mr_fixit
Drives: kids car
good info, lots of choices, thanks.
Old 05-15-2020, 08:28 AM   #8
Steve35
Steve35's Avatar
Drives: 2008 HB
Look what 06YarisRS did here
https://www.yarisworld.com/forums/sh...ad.php?t=62503
I love what he did.
Steve
Steve35 is offline   Reply With Quote
Old 05-16-2020, 07:37 PM   #9
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
OEM Yaris RS wheels are pretty easy to find, they're 15" too.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 05-17-2020, 10:46 PM   #10
mr_fixit
Drives: kids car
I found lots of wheels on car-part.com , just not anything I like close enough to me. Anyone have other junkyard on line databases that I can search?
Old 05-18-2020, 09:26 AM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I love what he did.
Steve
Thanks dude!
For the OP, here is my other set of accent wheels, painted in the body color (1E7 - Silver Streak Mica). You can buy a set if these wheels for a couple hundred bucks, often with excellent rubber remaining. IMO, these wheels look better than the 15" RS alloys. The Accent wheels a readily available in the classifieds. I found 3 sets in a couple of days. I posted a wanted ad.
https://www.yarisworld.com/forums/sh...hyundai+accent
You could try posting a want ad on Craigslist, for example. I used kijiji here in Canada. I got 2 replies in one day and another the next, and all were within an hour drive. People just throw these things in sheds and forget about them.
Old 05-18-2020, 04:01 PM   #12
mr_fixit
Drives: kids car
06 , Wow, I like those wheels!
Old 05-18-2020, 11:08 PM   #13
06YarisRS
Yeah, they go very well with the car, don't they. So happy Hyundai built them to almost identical specs.
Old 05-20-2020, 02:00 PM   #14
mr_fixit
Drives: kids car
Ok, found some mini wheels for cheap. Kinda look like the hyundai ones. One problem solved, next I’ll start a new thread on lug nuts...
WTB: OEM LB S Spoiler and Steering wheel hub adapter for aftermarket steering wheels kustom play Willing to Buy by private party 1 02-21-2009 01:42 AM
Stock wheels, tires and hub caps Trade Yarice Willing to Buy by private party 0 11-27-2008 04:59 PM
Wheels, Hub Caps, and Tires for sale.(Pics) PetersRedYaris Items for Sale by private party 2 03-03-2007 04:46 PM
