Old 05-23-2020, 02:50 AM   #1
Thedidat
Drives: YARIS
Replaced Rim
I recently had to replace one wheel due to bent rim. I forgot about the tire pressure sensor. I’m not that familiar with how that works. My question is how do I go about fixing this so that i can once again rely on the warning system?
For obvious reasons the tire pressure warning light is on.
Thedidat is offline   Reply With Quote
Old 05-23-2020, 06:33 AM   #2
alanwagen
The sensors are the valve stem. You should of used the same valve stem and then it will be ok. Otherwise you will need to buy a new sensor and have a tire shop pair it to your system.
Is getting the rim repaired worth it? nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 10-10-2014 04:22 AM
Rim 13" or 14" Yaris Hatchback 2008 Bearmantle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-19-2013 12:11 PM
I NEED A 15" STEEL RIM AND OEM TIRE robkay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-18-2009 10:57 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
