Old 05-23-2020, 03:02 AM   #1
rajee
Drives: Yaris I
Headlight not working / Flash light works !!!
Hei ,
I had a problem in headlight.
Flash lights working but normal light is very dimmed ( like not working ).
Any idea , what's wrong.
Im having TOYOTA Yaris I Hatchback (XP10) 1.0 16V (50 KW / 68 HV
Thanks in advance.
rajee is offline   Reply With Quote
Old 05-23-2020, 05:22 AM   #2
Check the headlight fuse. It may be partially burned out. It happened to me once. Replace it regardless.
Old 06-02-2020, 04:37 PM   #3
IndestructibleYaris
Order bulbs from rockauto! 2$ each
Check wiring with multimeter after bulbs are tested
IndestructibleYaris is offline   Reply With Quote
Old 06-02-2020, 10:16 PM   #4
CrimsonEclipse
Drives: .
If you replace the fuse and it immediately burns out, you may want to replace the headlight stem.
I had the same problem.
When the stem (wand) switch wares out, it's short and blow the fuse.
I was isolated and at night time so I used a 20A fuse to get me home for repairs.
(NOTE: Using a higher amp fuse is dangerous and should only be use in extreme circumstances)
CrimsonEclipse is offline   Reply With Quote
Remote start stopped working after installing LED brake light bulbs xdeslitx DIY / Maintenance / Service 0 04-02-2019 01:12 AM
Yaris High Beam Issue Only one headlight is working mik23 DIY / Maintenance / Service 10 12-30-2018 06:53 PM
P/S, Airbag lights on, Radio,fan,brakes light stopped working. sarabjeet19 DIY / Maintenance / Service 4 01-31-2016 11:00 PM
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 08:53 AM
