Old 06-07-2020, 07:11 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Throttle Body Gasket Screen?
For those in the know, is there expected to be any adverse effects if I am to remove the little 1/2 screen that is moulded into the throttle body o-ring? I am solely interested in doing this to improve my atomized water/methanol delivery into the throttle body. Any obstruction whatsoever starts to bring the water methanol mixture out of suspension.
I am also toying with 2 ideas: 1) install a throttle body spacer and spray directly into the manifold or 2) direct port injection - one 30cc/min nozzle in each runner, close to the head.
Old 06-07-2020, 09:04 PM   #2
Neinris
I thought it's only there so that the throttle flap don't go over past parallel? Not sure, I'm probably wrong. Maybe you can remove the first layer with the screen? Actually I might do that, since I'm gonna go with the 1ZZ TB for now since I don't have the $$$ for the engine swap yet.
Old 06-08-2020, 01:04 AM   #3
I believe those honeycombs are there to straighten out the air or something like that so that the MAF sensor has an accurate reading. Not 100% sure on that tho. But I think that's also the same reason why K&N had some kind of flap in their intake pipe.
Old 06-08-2020, 06:05 AM   #4
06YarisRS
Thanks! Yeah, I'd like to remove it. I was thinking I might use something like my Dremel tool to carefully cut it away. Maybe I should have a replacement on hand. Lol.
Old 06-08-2020, 06:07 AM   #5
06YarisRS
I believe you are correct. Hopefully removing it won't cause erroneous readings.
Old 06-09-2020, 10:12 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Seems like there's a lot of confusion on the web about it:
https://www.justanswer.com/toyota/4m...-throttle.html
https://www.spyderchat.com/threads/s...purpose.71002/
It's there for a reason, even if it's not publicly visible. =)
Old 06-09-2020, 09:15 PM   #7
06YarisRS
Interesting reading. I wonder about the spark arrestor function as it only covers about 1/3 of the opening. But, for sure, Toyota put it there for a reason. I think I'll leave it in place.
Successful 1ZZ Throttle Body Swap rabbito Performance Modifications 34 10-15-2024 07:12 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
