Old 06-14-2020, 10:15 AM   #1
Neinris
72mm Throttle Body
For now, I'm doing the 1ZZ TB swap to my 1NZ-FE until I do the 2ZR-FE swap.
I was browsing through the internet and came across this:
https://gramsperformance.com/inducti...w-frs-brz.html
The stock TB size for the BRZ/FRS are 65mm, like the 2ZR-FE. Sooooo... yeah... I didn't see any threads about it. Those with the 2ZR engine already have you thought about doing this?
Old 06-15-2020, 11:28 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The FT/BRZ/FRS use a Subaru engine, no idea if the TB is compatible with Toyota ECUs. You'd have to check the pin compatibility as well as signals since the connector is completely different. I suspect that it's not compatible with the mounting stud spacing either so you'd have to make an adapter like Tooter did for his crazy manifold project.
Ambitious? Yes. Worth the engineering involved? Maybe.
Old 06-28-2020, 12:49 AM   #3
Neinris
I forgot about this... LOL! Actually the stock TB connector looks the same as the one for the Toyota. What is the stock TB size for the 2ZR-FE, 55mm? The stock TB for the FRS is 65mm. Mix that with the 2ZZ intake manifold...
https://www.toyotanation.com/threads...#post-14000058
I wonder what gains will you get if any?
Old 06-29-2020, 04:56 PM   #4
CrankyOldMan
Only one way to find out. ;)
Old 06-29-2020, 08:38 PM   #5
Neinris
DOOO EEEEEETTTT Cranky... :DDDDDDDDDDDD
Old 06-30-2020, 02:43 PM   #6
CrankyOldMan
Lol, I was suggesting that you try it first. =P
Old 07-01-2020, 10:27 PM   #7
Neinris
I'm still sporting the 1NZ engine...
The auto hobby shop that I go to is currently shutdown by COVID. The only thing I can do for now is install the 1ZZ TB to play around with it my Dee Dee.
Successful 1ZZ Throttle Body Swap rabbito Performance Modifications 34 10-15-2024 07:12 AM
Throttle Body Swap Ryze268 Performance Modifications 12 04-27-2014 01:46 PM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
