Old 06-24-2020, 10:23 AM   #1
Pinchlite
Drives: 2007 yaris HB
Roof Rails...NOT rack
I was at thule dealer and he said he did a yaris 3DR that had roof rails(Not rack)
The rails appeared to be factory and all that was needed was cross members which he installed.
Only thing that comes up are these rails.
These are only cosmetic though.
Anyone know anything about load bearable rails for the yaris.
He said they went in the roof seems where the 2 metals are joined.
These are decorative but gives idea.
https://www.aliexpress.com/item/32878092132.html
Pinchlite is offline   Reply With Quote
Old 06-24-2020, 11:23 AM   #2
https://www.yarisworld.com/forums/sh...ad.php?t=29812
Old 06-24-2020, 12:12 PM   #3
Pinchlite
Tracks.
He said the rails that were already on the car looked stock.And went where the plastic strips are on the roof.
Yakima Track With Plusnuts looks like the way to go if no toyota roof rails are available.
The tracks are a bonus since the rack can be removed.
Thanks for the link.
Old 06-24-2020, 12:59 PM   #4
As far as I know, rails were never a dealer/factory option.
Old 06-26-2020, 04:45 PM   #5
Pinchlite
Custom
I may use this and drill my own holes.
The length/width can be lessened.
Thule and yakima are way over priced for what it is and needs to do.
I think I will DIY it.
Only needs to carry a 30lb 8 ft kayak.
https://www.amazon.ca/ROKIOTOEX-Univ...NsaWNrPXRydWU=
Old 06-30-2020, 12:03 PM   #6
GrayYaris
Drives: Gray
Sounds like you have your mind made up, but I have my Thule Traverse rack system sitting around still (sold the Yaris). I'll sell it to you for a reasonable price.
GrayYaris is offline   Reply With Quote
Old 06-30-2020, 03:11 PM   #7
Pinchlite
rack/s
I appreciate the reply and offer.
I went with the amazon one I linked.
I wil be drilling hole in channel and use a stud with nut on the inside and nut in the channel.Its gonna be rock solid.
I also got a thule wind deflector to go with it.
Even if I was willing to spend the thule or yakima price I find It bulky and not a fan of the hook system.
I may post pic/s when done?
Old 06-30-2020, 04:06 PM   #8
You will definitely post pics when done. Not just end result either. Since so few rail installs have been done, we need another one with a pictorial documentation of the process.
Old 07-01-2020, 06:38 AM   #9
Pinchlite
Rack not rails.
They are not considered rails but rack.I linked item.
I was talking to an auto body friend and he says the metal is thick in the roof ditch area.He said 5-6mm wide bolt type screws would hold the rack no issue.
He said you could probaly pull the bars off before the mounts would come off?
He said using stud wouldint really be that much stronger and considering rack is only holding 38 LB kayak anyway.
Old 07-01-2020, 11:48 AM   #10
A fixed crossbar install has never been done. Definitely need full pictorial for future reference.
Old 07-01-2020, 03:30 PM   #11
Pinchlite
document.
I will be screwing down to make the process easier and use what parts I already have around.
Not much to document but I will post how I did it with pics.
Will a 5-door roof rack work for a 3-dr hatchback? 2006. fuzzybabybunny General Yaris / Vitz Discussion 0 02-23-2016 05:13 PM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
Catastrophic Yakima Roof Rack Failure Kaykogi General Yaris / Vitz Discussion 8 08-14-2012 03:59 PM
Yaris 2 door Hatchback Thule roof rack question dasnake Cosmetic Modifications (Exterior/Interior) 5 03-22-2012 12:15 PM
Another roof rack option for Yaris! Cosworth General Yaris / Vitz Discussion 6 08-07-2011 10:29 PM
